January 7, 2017, 17:02 |
Restarting a Steady Problem in CFX
beyonder
Rep Power: 10 |
I am trying to confirm if there is a way to restart a steady problem if the solution is interrupted midway or due to system shutdown. There is no backup or result file created. There are some files created but I can't figure out how to get some useful information out of it. I have uploaded the list of files that is created. |
January 8, 2017, 05:02 |
Rep Power: 143 |
If you did not set it to do backup files as the simulation progressed (or you did not manually trigger a backup file in the solver manager) then the simulation is lost. You will have to start the simulation from the beginning. I do not see any backup files in your file list, so you will have to repeat the simulation from the beginning.
This is why, for critical runs, you always configure it to save backup files as it progresses (this is for steady state runs, transient result files are used for backing up transient runs). |
January 8, 2017, 12:33 |
beyonder
Rep Power: 10 |
Thank you for the clarification.
CFX parallel hp MPI problem | fluidmechanics | CFX | 5 | June 19, 2013 19:05 |
cfx mesh problem... | mactech001 | ANSYS Meshing & Geometry | 0 | November 5, 2009 02:19 |
Ansys Workbench (CFX) bucket problem | njsavage | CFX | 1 | April 30, 2009 09:51 |
Urgent Problem with Hypermesh and CFX | Luk | CFX | 5 | March 14, 2008 04:59 |
CFX 5.5.1 stirred tank and LES problem | Nishant | CFX | 2 | September 13, 2002 07:11 |
