February 14, 2004, 05:36 |
thermal phase change question
Hi,all friends. I try to model a thermal phase change project. Some subcooling water is injected into the pipe and meet the hot gas(c3h8) in the pipe. A part of water is boiling to be vapour. I try to model it with cfx5.6, but when I select the thermal phase change, the solver will overflow. I have check the transient result, all the water is evaporated, even near the water inlet. It is not reasonable. And I make a test model there is only water and vapour, the result is same.
I have no idea about it. Could you give some advice? Or send me a simple example about thermal phase change model. Thanks. |
February 18, 2004, 04:10 |
Re: thermal phase change question
I have same task. Water injected into column for cooling hot humid air. I use multicomponent (humid air = air + vapour) multiphase (humid air + water) simulation. The mass evaporated water I define with CEL expressions and use SUBDOMAIN to set mass and energy source and sink.
simulation of phase change material melting | rosol | FLUENT | 4 | December 8, 2015 07:56 |
Instability in phase change computations | quicksilver | Main CFD Forum | 5 | June 6, 2009 10:25 |
How to model the solid-fluid phase change in CFX | ohrmond | CFX | 2 | May 26, 2006 06:27 |
Phase change process | Sang-jin Lee | Siemens | 5 | December 5, 2001 05:17 |
Phase change modelling | Sebastien DANIEL | FLUENT | 1 | July 6, 2000 03:35 |
