CFX mesh generation techniques
Old   May 19, 2005, 15:50
Default CFX mesh generation techniques
M.Jutla
Any advice on how to create schemes for meshing 2d and 3d surfaces using mapping, triangular and quadrilateral mesh elements? How can you get the grid points to cluster at walls (ie boundaries)
If this is really obvious, just point me in the right direction.....
Old   May 19, 2005, 18:29
Default Re: CFX mesh generation techniques
You do not need to create meshing schemes as many mesh generation packages already exist which allow tri and quad meshes with clustering at walls. CFX comes with ANSYS Workbench and/or ICEM for its meshing, and can import meshes from just about any other mesh generation package.
Both ANSYS WB and ICEM can be used to generate 2D meshes suitable for CFX. Note the 2D mesh needs to be extruded into a single element thick 3D mesh for the CFX solver.
Unless of course you wish to write your own meshing code, and in that case you are a little off-topic here in CFX land.
Regards, Glenn Horrocks
Old   May 24, 2005, 03:08
M.Jutla
Thanks for that - that helps me tell the wood from the trees with the cfx notes I have been looking at online! Which particular website on the cfx website would help me with this part of things? Cheers MJ
Old   May 24, 2005, 18:40
Look on the ANSYS website for the CFX meshing packages - ANSYS Workbench and ICEM CAD2MESH.
Regards, Glenn
Old   June 26, 2005, 09:21
jalal ghasemi
Hi How can we generate mesh in ANSYS enviromenet and export that to CFX software
regards
hex mesh using cfx mesh. mehul CFX 0 October 31, 2005 07:01
Mesh conjunction in CFX Twiti CFX 4 January 10, 2005 20:35
importing mesh from ICEM CFD into CFX 5 Jay CFX 2 November 12, 2002 13:46
Latest News in Mesh Generation Robert Schneiders Main CFD Forum 1 February 18, 2000 00:48
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 04:07
