Creating inflation layers for elbow with airfoil !
Old   March 12, 2006, 12:12
Default Creating inflation layers for elbow with airfoil !
Aplus
Hi
I have an elbow channel which has airfoils close to the exit. To simply the simulation, two periodic walls along the width (say in z-direction) were assumed so that only one airfoil close to the exit existing for the simulations and meshing. Using the right hand rule, the flow inters in the x-direction and exits at the y-direction. The elbow is extruded in the z-direction while the airfoil is extruded ( by removing materials) in the y-direction. Therefore, the direction of the extrusion for the airfoil and the channel is NOT the same. I want to create an inflation layers around the airfoil and close to the walls (the non periodic walls) but I can't create accurate inflation layers distribution. I am using ANSYS-CFX10 for meshing. Please can you help me to find out how to make a perfect inflation layers around the airfoil as well as the walls.
Regards Aplus
Old   March 13, 2006, 22:22
Default Re: Creating inflation layers for elbow with airfo
TB
I assume you're referring to tetra mesh. If so, are you using CFX-mesh or ICEM?
For ICEM: If you have defined a part name for the airfoil surface, you need to check the box for this part so that ICEM will know which wall you wishes to get the inflation layer. Have you done that?
I can't give you any suggestion if CFX-mesh is used.
inflation layers for hexa mesh using icem cfd Apple CFX 4 January 6, 2012 00:12
creating lines normal to airfoil surface iffy CFX 6 July 20, 2011 06:40
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 11:31
Inflation layers / boundary layer meshing. andy2o Main CFD Forum 3 February 22, 2009 09:03
creating airfoil geometry using ICEM CFD jaber Main CFD Forum 1 November 2, 2007 16:26
