September 21, 2020, 21:07 |
Porous domain set up
Pedro Pena
Rep Power: 6 |
Good day,
I was setting up a porous domain to simulate a pressure loss inside a fluid domain, but I do have a couple of questions regarding the set up. The porous domain is a cylindrical screen (cylinder with small holes), something the attached picture. From this screen I already know its linear and quadratic resistant coefficients (from charts). My questions are: 1.- From the porosity settings tabs, what is the intention of volume porosity? I am asking this because with the linear and quadratic coefficients we are supposed to include the consideration of the opening area. 2.- As my screen will act only in the radial direction, I selected the option “Cylindrical components” under the streamwise direction settings and put a “1” on radial component and “0” on axial and theta components, then for rotation axis, I selected a “coord 1.3” which I believe is the “Z axis” for the custom coordinate system I created (As shown on attached image), the Z axis of this custom coordinate system is the same as the axial direction of the screen. Is this set up correct? Or how do I specify the actual radial direction for this case? Thanks in advance, P.P.example.jpg |
Heat transfer porous domain - between solid part and sourounding fluid | Janis_K | CFX | 0 | May 18, 2020 05:09 |
Periodic Pressure drop | cfd_begin | CFX | 10 | May 25, 2017 07:09 |
define porous zone in fluid domain | pannsave | FLUENT | 0 | March 24, 2014 07:27 |
No turbulence generation in a porous domain | siw | CFX | 3 | September 25, 2012 08:10 |
Porous domain set-up from single pressure loss value | siw | CFX | 1 | December 8, 2011 16:36 |
