Upwind scheme
Like Tree1Likes
  • 1 Post By CycLone
Old   September 25, 2007, 18:45
Default Upwind scheme
KM
Hi there,
I know that upwind scheme should only be used for the initial guess but not for the final results. Can we believe on results from upwind upto an extent, to do some analysis if our model physics is working fine ? Or these results are not good for any kind of analysis ?
Regards, KM.
Old   September 25, 2007, 23:21
Default Re: Upwind scheme
Problem dependant, so cannot give a general answer. Do a run using both and compare for your application.
Old   September 26, 2007, 11:10
CycLone
Hi KM,
All CFD analysis includes some degree of error. Running with a first order upwind advection scheme simply means that the error is going to be larger for a given grid resolution and therefore will require a much finer mesh to minimize this error.
An easy way to estimate the magnitude of this error is to compare results using upwind to High Resolution or a Specified Blend Factor. You'll find that the difference is largest on a coarse mesh and is reduced as you refine the mesh.
-CycLone
dgfemkadri likes this.
Old   September 27, 2007, 14:41
Kushagra Mittal
Thanks a ton ! It helps.
Regards, Kushagra.
Default Thanks: Upwind scheme
Kushagra Mittal
Regards, Kushagra.
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 12:29
Use of upwind scheme for interpolation of u/v quarkz Main CFD Forum 6 August 30, 2011 04:10
Second order upwind is not UPwind!!! Far CFX 9 May 31, 2011 08:21
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
Drag comparison upwind vs. scheme Luk_Fiz CFX 3 April 27, 2009 21:42
