Unit Normal vector Component Divided by Zero
Old   February 22, 2023, 03:11
Default Unit Normal vector Component Divided by Zero
gyr
libya
gyr is on a distinguished road
I am running a 3D Transient simulation of Mixture model (water&air),the problem when I try to compute the unit normal vector components Nx,Ny,Nz at the interface that defined as fluid(water or gas)volume fraction gradient X,Y,Z divided by magnitude of total of fluid volume gradient.when running a case, my simulation crashes as the unit normal vector divides by 0.and if i cancel unit normals expressions from ccl and rerun solver all volume fraction gradient are ok
gyr is offline   Reply With Quote
Old   February 22, 2023, 04:19
You will need to put something in your function to handle when the gradient is zero in all directions. Use the if() statement, or something like it, so you do not do the divide when the gradient is zero.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 22, 2023, 04:28
gyr
libya
your quick reply is appreciated thanks.really i ve to find which interrelatd function.i mean normal units needs free surface to be calculated.if i get normal units thats mean the free surface is istablished.i ll try interface length scale as conditional statement as i think it is not zero
Old   February 22, 2023, 04:47
Or maybe just simply make the function something like:
ComponentX = if(GradMag == 0, 0, GradX/GradMag)
Old   February 22, 2023, 10:33
gyr
libya
i tried problem still persist
The problem was:
| DIVIDE-BY-ZERO
| FURTHER INFORMATION
| The problem was encountered in executing the expression for:
| Gas Normal X
| The complete expression is:
| (Gas.vf.Gradient X/AIAD VF Grad Mod Gas )
| The error occurs on sub-expression:
where AIAD VF Grad Mod Gas is the magnitude
Old   February 22, 2023, 14:31
Gert-Jan
Gert-Jan will become famous soon enough
You are dividing by zero. Why don't you use the min-function?
Gas Normal X = Gas.vf.Gradient X/min(1e-6; AIAD VF Grad Mod Gas)
Gert-Jan is offline   Reply With Quote
Old   February 22, 2023, 15:13
gyr
libya
Both expressions didnt work
The problem was: |
| DIVIDE-BY-ZERO |
| FURTHER INFORMATION |
| The problem was encountered in executing the expression for: |
| Gas Normal X |
| The complete expression is: |
| Gas.vf.Gradient X/min(1e-6[m^-1], AIAD VF Grad Mod Gas)
Old   February 22, 2023, 15:29
gyr
libya
The geometry consists of two horizontal tubes (T-section) and the flow of both fluids develops properly before they are mixed together.may be at first simulation time is really there is no gradient or change in volume fraction.i am not sure
Old   February 22, 2023, 15:33
Gert-Jan
You have a gradient. So this might range from large negative values up to large positive values. Therefore you should create a function that prevents diving by zero coming from the negative direction and the positive direction. Currently, you are only protected for Division by zero coming from the positive direction.
Old   February 23, 2023, 00:11
gyr
libya
i found the same issue but in openfoam
Unit Normal Vector and Interface Jump ||.||
but i didnt catch the solution as i dont used to use openfoam
Old   February 23, 2023, 03:26
Your function is incorrect, try
Gas Normal X = Gas.vf.Gradient X/max(1e-6; AIAD VF Grad Mod Gas)
Old   February 23, 2023, 03:36
Gert-Jan
Indeed. It was late in the evening........
Then still, now the equation caps all gradients with a negative sign. Therefore gyr should define an equation himself that caps very small negative and positive values. Then it might work.
Old   February 23, 2023, 03:46
I am assuming gyr is calculating the gradient magnitude correctly - this should not ever be a negative number.
Old   February 23, 2023, 04:24
gyr
libya
ohhh i ll try Max function and feedback.thanks for Gert-Jan&ghorrocks
Old   February 23, 2023, 05:40
gyr
libya
it worked thanks again
Unit Normal Vector and Interface Jump ||.|| mcfdma OpenFOAM Programming & Development 3 February 20, 2023 09:00
Need help setting up chtMultiRegion OskarT OpenFOAM Pre-Processing 1 September 25, 2019 15:51
Grid I Unit Normal and Grid J Unit Normal pawansut Tecplot 4 July 31, 2017 18:14
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
