Use of restitution coeff without kinetic theory
Old   June 11, 2008, 04:29
Default Use of restitution coeff without kinetic theory
Kushagra
I am simulating a system with solid particles (dispersed phase) and the water (continuous phase) using Eulerian-Eulerian approach.
Suppose I do not want to use kinetic theory or any other model for solid pressure OR solid bulk/shear viscosity to account the particle-particle collision.
Now, Will there (still) be any use of specifying the restitution coefficient for the dispersed phase? I looked in to the manual but the momentum equations for solid phase are not given in much detail.
Please help.
With very kind Regards, Kushagra
Old   June 11, 2008, 12:33
Default Re: Use of restitution coeff without kinetic theor
Mehul
I also had read the manual for multiphase flow modeling after you have raised the question for more clarification.
Now, in your case if you are cofident enough that the particles will not transfer momentum to each other then, specifying the restitution coefficient will not be of use.
You have to decide from the nature of particles that you are handling as dispersed phase.
Old   June 11, 2008, 12:55
Default Restitution coefficient
Kushagra
Thanks very much Mehul. Could you please suggest me some reference for estimating the restitution coefficient for different materials? In my case I am using 'Polystyrene' particles. with very kind regards, Kushagra
Old   June 11, 2008, 13:24
Default Re: Restitution coefficient
Mehul
Sure Kushagra, I have used restitution coefficients for cement material in cyclone seperation. I will have to search in my literature . I will get back to you if I find suitable material in this regard.
Old   June 13, 2008, 08:21
kumar
Guys i m doing similar kind of simulation.
Why not have a team.
Old   June 17, 2008, 21:52
Kushagra
Yes Kumar. I will be very happy to share our knowledge. I am working upon cyclones. How about you?
Old   June 18, 2008, 04:14
kumar
i m working on dryer.
Old   January 27, 2015, 13:36
Default restitution coefficient
Hesam
sorenasrn is on a distinguished road
Hi
How do i define restitution coefficient for kinetic theory in ansys cfx?
Is there any where that I put my value?
sorenasrn is offline   Reply With Quote
udf for cohesive forces in kinetic theory T.Hari FLUENT 1 October 6, 2014 14:41
Mixture model and kinetic theory Fuping Qian FLUENT 3 January 24, 2011 06:58
Kinetic Theory in Multiphase mtl Main CFD Forum 0 June 3, 2009 22:54
Kinetic Theory Tommaso Main CFD Forum 1 June 30, 2003 10:06
solid kinetic theory wan xiaotao Main CFD Forum 6 August 10, 1999 18:43
