August 15, 2011, 01:48 |
Constant mean WSS
Hi
How can I apply constant mean WSS at inlet? Is that the same concept of constant velocity?? Thanks |
August 15, 2011, 13:14 |
sajad
hi.
what do you mean a constant wss at inlet? wall shear strees depends on velocity gradiant no on velocity. could you expllain your problem more? |
August 15, 2011, 18:54 |
Rep Power: 143 |
If you want to do constant wall shear stress then just define the wall shear stress to be a constant value. Use the specified shear option in CFX-Pre.
August 15, 2011, 22:23 |
Because of different size of vessel in different patient, some people assume that applying constant value for mean WSS at inlet for example basilar artery is the right assumption for patient specific modeling.But I don't know how we can apply it in Cfx-pre?
Any idea? Thanks |
August 16, 2011, 06:43 |
Rep Power: 143 |
I just told you how to do it. Please read my previous post.
August 16, 2011, 08:02 |
sajad
im not sure but i think constant WSS is applied on artery wall not as an inlet boundary condition.
check your artery wall and you will see that in "boundary detail" in "mass and momentum" the defualt is "no slip " for wall.but you can set "free slip wall"...or...."especifed shear" too. i hope i could help you.. can you say me what is yous problem in general? |
Chemical properties that are used in Fluent | kimej | FLUENT | 4 | August 19, 2011 11:29 |
Constant Volume Combustion with reactingFoam | Alish1984 | OpenFOAM Running, Solving & CFD | 2 | May 8, 2011 08:51 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Really big problems when creating own materials da | Jop | FLUENT | 0 | June 28, 2007 11:15 |
