Home > Forums > Software User Forums > CONVERGE
process rank 12 with PID 25320 on node exited on signal 9 (killed).
Old   February 28, 2018, 14:58
Default process rank 12 with PID 25320 on node exited on signal 9 (killed).
Nitisha Ahuja
Nitisha is on a distinguished road
My simulation ran till before it had to write the 2nd post.out file. Then It gave error:
mpirun noticed that process rank 12 with PID 25320 on node exited on signal 9 (killed).
I dont understand what process rank 12 is. What could be the reason for this error and how I can correct it?
Thanks
Nitisha
Nitisha is offline   Reply With Quote
Old   March 1, 2018, 10:13
yli
Yanheng Li
yli is on a distinguished road
Process rank 12 is one of the cpu processors (you must have 12+ of them). Looks like it crashed during post-processing. How many cells do you have and how many cores are you using? Can you try to use less or more cores to see whether this crash repeat?
Yanheng Li
Research Engineer-Applications
CONVERGECFD
yli is offline   Reply With Quote
Old   March 1, 2018, 10:56
Nitisha Ahuja
I have 32 CPUs,
I run my mpirun command with mpirun -n32
No of cores per socket are 8.
There are 2 sockets
Is it possible that writing output file interval can effect the simulation, as when I changed my writing interval from 2 degree to 10 degrees, then the simulation crashed.
Old   March 1, 2018, 13:28
Nitisha Ahuja
as per the information about my computer, how many processors should I use?
Old   March 1, 2018, 14:47
Nitisha Ahuja
Hello, I tried the simulation with less no of CPUs. I used mpirun np-10 as a command. Still I get the same error. And now it happens write at the start of the simulation.
When I run the box spray simulation rather than Engine simulation. I dont get such error till now.
Thanks
Nitisha
Old   March 2, 2018, 12:43
yli
Yanheng Li
Hi, Nitisha,
For your simulation how about email us off-line and we have some one to help you diagnose what the problem is. Thanks.
Yanheng Li
CONVERGECFD
Old   September 15, 2018, 00:31
Saleh Abuhanieh
Saleh Abuhanieh is on a distinguished road
Hi, I know it is too late. As per the information provided you have 16 CPU (2*8) not 32
Saleh Abuhanieh is offline   Reply With Quote
Free Surface Ship Flow timfranke OpenFOAM Running, Solving & CFD 322 March 3, 2021 09:04
Linux Batch - Star-CCM+ .. running Sims in batchmode eRzBeNgEl STAR-CCM+ 3 August 29, 2011 04:43
MPI PROBLEMS gtg627e OpenFOAM Running, Solving & CFD 20 October 5, 2007 04:02
MPI_Recv process in local group is dead rank 44 MPI_COMM_WORLD sampaio OpenFOAM Running, Solving & CFD 0 January 9, 2006 09:43
Killed by signal 8 after first timestep matthias OpenFOAM Running, Solving & CFD 0 December 9, 2005 08:06
