Home > Forums > Software User Forums > CONVERGE
Spray D simulation
Old   May 26, 2023, 22:18
Post Spray D simulation
Tee
Teeoff30200 is on a distinguished road
Hi, I am working on validating a vapor penetration for Spray D. I'm experiencing significant errors when comparing the results with experimental data. I'm seeking suggestions on the choice of a RANS model, grid size, AMR, and techniques that can potentially improve the accuracy of my simulation. Any advice from the community would be greatly appreciated
Teeoff30200 is offline   Reply With Quote
Old   July 31, 2023, 17:55
Achyuth Rajendran
arajendran is on a distinguished road
Hi Tee,
We have a similar spray in our suite of example cases - 'ECN Spray A Lagrangian Transient RANS'. We would recommend you try the case settings used for that case here as a first step.
arajendran is offline   Reply With Quote
Old   September 28, 2023, 21:10
Harsimran
Harsimran_7093 is on a distinguished road
If the vapour and liquid penetration lengths are not matching, lets say they are overpredicting as compared to experimental values. I suggest you to adjust Ceps1 in RANS turbulence model. This constant has direct effect on vap length. For liq length, adjust Spray model breakup time constant (b1), if you are using KH-RT.
Harsimran_7093 is offline   Reply With Quote
Simulation for water jet spray using fluent multiphase Daidalos94 Fluent Multiphase 0 August 16, 2020 09:44
Problems with spray simulation sara91 OpenFOAM Running, Solving & CFD 0 February 15, 2016 05:53
Spray Simulation - How to go about it? varunrajendra FLUENT 4 August 6, 2009 12:41
help, error spray simulation in contant volume chamber with kiva toto Main CFD Forum 0 June 8, 2009 09:52
Sofware for spray simulation Joe Main CFD Forum 3 December 10, 2007 16:07
