Frozen Rotor Simulations in SW Flow Simulation? |
Chris
Rep Power: 15 ![]() |
Greetings all,
I've been wondering, is it possible to do a true Frozen Rotor simulation in SW Flow Simulation? I know you can do a Mixing Plane (Averages) simulation, a transient sliding mesh simulation, or a single rotating reference frame simulation but there does not seem to be an option for just having multiple reference frames with no averaging between reference frames. |
Disabled
Rep Power: 24 ![]() |
Not sure it is clear what you mean with "true" frozen rotor.
The Averaging Plane model is not a frozen rotor model so there is no frozen rotor in the software that there is a "not true" frozen rotor, the averaging happens in the circumferential slices of the rotating region and you can have multiple rotating regions as well. The question is what are you trying to model? What is your application? Regards, Boris |
Display Modes | |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Flow rate restriction simulation set-up | siw | CFX | 4 | February 16, 2016 12:15 |
Numerical simulation of DBD plasma actuator induced flow | mukut | OpenFOAM | 5 | January 7, 2014 05:30 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 04:44 |
Coupling of drying process and flow simulation | franzdrs | Main CFD Forum | 0 | April 29, 2013 14:11 |
