March 17, 2020, 13:19 |
spray modeling in ansys fluent
Farnia
Hello
I am new to Ansys Fluent. I am trying to model a spray type inlet. I have read about the velocity inlet boundary condition. But I am not quite sure whether this is the appropriate BC. Could anyone please suggest if there is a better alternative? thank you |
March 17, 2020, 13:41 |
The Objective
The type of inlet or setup depends on the objective of the simulation. The available information is to be used to decide about the multiphase models to be used, e.g., if the initial diameters for the droplets are known, then standard DPM with breakup models will predict the spray characteristics. Another example is using the atomizer, provided an atomizer is being used in reality for spraying the liquid. Velocity inlet is only for continuous fluid, like a jet, and not for spray. But if the liquid comes out of the nozzle as a jet and then breaks into droplet, then you will have to use VOF + DPM. This option is expensive in terms of spatial and temporal mesh.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
spray modeling |
Fluent in Ansys Workbench : Change Working Directory | sral | FLUENT | 4 | March 29, 2019 10:29 |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro | cheezum | Hardware | 0 | February 28, 2017 10:23 |
Sediment modeling in ANSYS Fluent | shahab2710 | FLUENT | 11 | April 19, 2016 20:48 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 12:07 |
