Please help (an UDF for regulating the mass flow rate)
Old   July 7, 2015, 09:13
Default Please help (an UDF for regulating the mass flow rate)
saad
swidi is on a distinguished road
Hello friends I really need your help
I am trying to control the injection of the mass flow rate at a velocity inlet using a UDF. In fact I want to have the same mass flow rate at the inlet and at the outlet-pressour. So I need to put a condition at my velocity-inlet like if the two mass flow rates are not equal it has to stop injecting ( water ) until they ll be equal
I begun by this UDF, it only needs the regulation part
#include "udf.h"
DEFINE_EXECUTE_AT_END(measure_mass_flow)
Domain *d;
real flow=0.;
face_t f;
Thread *t;
t= Lookup_Thread(d, 12);
d = Get_Domain(1);
thread_loop_f(t,d)
begin_f_loop(f,t)
flow+=F_FLUX(f,t);
end_f_loop(f,t)
printf("MASS Flow Rate: %g\n",flow);
flow=0.;
swidi is offline   Reply With Quote
Old   July 7, 2015, 11:09
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Why do you expect the mass flow rate at the pressure outlet to be different from the inlet one?
However, the task is more difficult than the way you approached it. Both inlet and outlet surfaces can be irregularly distributed among different processes in parallel. So you need to consider this beforehand.
Moreover, even in serial, you need the flow variable to be available outside the routine computing it (which, by the way, i would write as a DEFINE_ADJUST instead of EXECUTE_AT_END) and a DEFINE_PROFILE routine to use it.
sbaffini is offline   Reply With Quote
Old   July 30, 2015, 12:32
Asim
asimavd is on a distinguished road
HI,
My case is rectangular channel with 0.45 mm to 3.6 mm and length 260.6 mm.it is small part of counter flow heat exchanger, with just 12 channels with four rows of hot and cold fluid flow channels.
re no is 1202 and 911 for hot and cold fluid respectively. I know the pressure inlet and temperature inlet and mass flow.
can someone tell me the BC and whether I should go for compressible flow or incompressible flow.
asimavd is offline   Reply With Quote
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
Mass flow rate of phase in post mat_cfd CFX 0 September 3, 2013 07:55
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
Mass Flow Rate student87 CFX 4 January 2, 2010 04:45
How to define mass flow rate using UDF? SAMUEL FLUENT 3 December 25, 2004 00:36
