April 20, 2012, 10:45 |
How to set up symmetry for simple 2D model?
Andrius
Hi guys,
I am trying to model turbulent axisymmetric flow. My approach is to draw half of the geometry and create a named selection (axis) to specify where I want the symmetry. My approach is to specify the 2D space to be axis symmetric and use axis boundary condition. However, this has failed. Is this the correct approach? |
April 20, 2012, 15:58 |
Ali
I think you are doing wrong. This case is not axi-symmetric but looks like planer.
I suggest rename axis with symmetry and run the case. is it circular geometry? if not, then follow my suggestion.
Best Regards Ali |
April 20, 2012, 16:06 |
Lucky
Rep Power: 66 |
You cannot change the default axis for an axissymmetric setup in Fluent. Your axis can only be the Fluent default. In other words, you cannot choose an axis or choose where you want symmetry. That may be your problem. I believe the default is the x-axis, centered at y=0 and z=0 (check it on Fluent manual to be sure).
April 20, 2012, 20:43 |
Andrius
It worked when I drew it using x-axis as symmetry!
However I have realised that it may be incorrect, I am studying the circulation past the bluff body and each side has an effect on each other... |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
the initialization of the coupled level set method and vof model in FLUENT 13.0 | dutliang | FLUENT | 3 | December 13, 2011 21:28 |
whether we can set up more tables in one model | limingtiger | Siemens | 2 | August 17, 2005 20:02 |
How to set Low-Re k-e model | Frank | FLUENT | 2 | June 24, 2004 20:03 |
Can we model spherical symmetry in Fluent !!! | Ashish | FLUENT | 1 | April 29, 2004 10:07 |
