What are the internal numerical data types used by FLUENT?
Old   July 16, 2015, 07:18
Default What are the internal numerical data types used by FLUENT?
Leb
V.Leb
Leb is on a distinguished road
Hi everyone,
I was wondering what is the default numerical data type FLUENT is using. In the manual I can find this:Lhttp://www.afs.enea.it/project/neptunius/docs/fluent/html/udf/node252.htm
but it's for UDFs.
The reason I'm asking is because I wonder if running a simulation on a mesh that has micro meter scale system expressed in meters (i.e. length scale etc. units are read as meters in FLUENT) would be worse/not converge as fast as one using micro meter scale in FLUENT (i.e. instead of having 0.000001m I would have 1um when FLUENT is calculating). I guess if FLUENT is using at least float precision, then this wouldn't be a problem...
Cheers
Leb is offline   Reply With Quote
Old   July 16, 2015, 12:08
Andrew Kokemoor
Kokemoor is on a distinguished road
The default is single (float) precision, but double is supported and easy to enable. In the GUI launcher, there's a checkbox for it. If you're launching from command line, add "dp" to the solver flag, e.g. -3ddp instead of -3d.
Kokemoor is offline   Reply With Quote
Old   July 21, 2015, 11:15
Leb
V.Leb
Thanks, I realised that after I have posted the question. I'm a bit surprised that it makes a difference in convergence ( I thought floats "dynamic range" would be more than enough...).
fluent 12.0, scale factor, units
high continuity Fluent modeling ABL with WRF/CALMET data xitao21 FLUENT 1 May 2, 2019 10:20
OpenFoam to Fluent data conversion Problem vemps OpenFOAM 1 August 8, 2011 02:30
How to read tabulated data in Fluent Siddhartha Pal FLUENT 0 August 30, 2007 05:18
reading data into fluent co2 FLUENT 0 December 28, 2003 01:31
Boundary Types in Fluent 5/6 Oresko FLUENT 3 July 23, 2002 19:23
