velocity difference ?
Prev Previous Post   Next Post Next
Old   December 30, 2015, 01:54
Default velocity difference ?
cglr
wales is on a distinguished road
I have been dealing with the air flow in a narrow duct comprised of two thin long plates that have a particular temperature. Id like to observe the heat transfer rate between air and plate. I have good mesh at walls ( 0.2<y+<2) and utilized sst model.
The thing I could not understand is although I set the inlet velocity 5,4 m/s in the boundary conditions tab, when postprocessing I see a region which has a velocity of 6.08 m/s or velocity bigger than 5,4 (you can see in the attached picture)
Id like to see your comments on that. is it possible ?
Note: I initialized as all-zones
wales is offline   Reply With Quote
In fluent post processing, difference between, x velocity and axial velocity? padmanathan FLUENT 3 December 20, 2014 15:13
Velocity distribution function sampling issue in DSMC flotus1 Main CFD Forum 6 December 13, 2014 06:18
Unexpected difference between velocity / mass-flow inlet jpo FLUENT 8 December 10, 2010 07:20
difference of velocity field processed by CFD-POST and Fluent Jiuan CFX 3 June 16, 2010 08:23
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
