Structured (Cutcell) vs Unstructured (tetrahedral) meshes difference in Fluent result
Old   August 16, 2016, 12:44
Default Structured (Cutcell) vs Unstructured (tetrahedral) meshes difference in Fluent result
Stan_Mech is on a distinguished road
Hello Guys,
I am trying to investigate the difference in the results if I use structured (cutcell) mesh vs unstructured (tetrahedral) mesh in fluent. I am simulating hot airflow (60 m/s at 900 K) passing through a catalytic converter, and in cases that I compared using k-omega turbulence model the cutcell mesh produced double the TKE than the tetrahedral mesh in the flow expansion and contraction areas in the geometry.
Anyone has ever compared two types of meshing techniques and would like to give any input?
Thanks,
Mike
Stan_Mech is offline   Reply With Quote
Old   August 20, 2016, 20:30
Daniel Riveros
DRiver is on a distinguished road
Hi Mike. I have done this type of comparison, I have got similar results. If you're sure you're using the same initial conditions, you must try to do a mesh independent analysis for each method. You can only compare your results when you get converged values. If you already did it, please tell us.
DRiver is offline   Reply With Quote
fluent, turbulence
How cell skew affects solution in structured vs unstructured grids lordvon Main CFD Forum 1 July 3, 2013 06:19
Different result in CFX and fluent for mass trans.? is segregated better? ftab CFX 7 September 27, 2012 07:57
Difference between structured & unstructured mesh Andrew Main CFD Forum 2 February 20, 2003 08:40
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 03:33
Unstructured CFD code; Difference ?? J Roued Main CFD Forum 2 May 13, 1999 13:03
