November 21, 2016, 09:01 |
Wall roughness effect on laminar flow
Hannes
Rep Power: 9 |
Hello!
I have a flow with very low Reynold number (below 1) in a axisymmetric pipe simulation and I have no slip condition on the pipe wall. When I change the wall roughness height of the pipe wall I get different pressure losses (lower pressure loss with higher wall roughness height) even though i should not? The pipe diameter is 0.3 mm and I vary the wall roughness height from 5 micrometers and up. Do you know why this is happening? Thanks in advance |
November 21, 2016, 11:01 |
In order to modify the roughness parameters for a wall you necessarily need to have a turbulence model on, which seems wrong at your low Re number.
Moreover, roughness effects are models as much as turbulence models are. That is, they model something below the scale you can actually reach with your grid. So, in practice, they are only introduced trough wall functions and not for fully resolved walls (or, nonetheless, the model becomes quite questionable for fully resolved walls). So, in practice, you are actually seeing the effect of the roughness trough a wall function and a turbulence model, both of which seem pretty wrong to me for your specific case. |
Effect of Wall Roughness in Low-Turbulence simulations? | gabitinho | OpenFOAM Running, Solving & CFD | 0 | December 17, 2015 07:42 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Surface roughness in laminar flow | carno | FLUENT | 4 | August 19, 2007 15:52 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
