FLUENT postprocessing
Old   July 29, 2017, 14:12
Default FLUENT postprocessing
Mohamed Mousa
Mohamed Mousa is on a distinguished road
Dear all,
I ran a multi-phase (VOF model) case and I set solution animations. After calculations I need to add another contours to be animated.
Is it possible to set new animation after calculation ?
Another problem, when I attempted to use the CFD post instead, there is no option for "volume fraction". Only density, wall heat flux and radiative heat flux are the properties available for each phase to be displayed.
Thanks in advance
Mohamed Mousa is offline   Reply With Quote
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 10:54
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 11:55
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
fluent journal files - speedup your postprocessing warlock FLUENT 0 March 8, 2006 23:36
