May 9, 2018, 13:30 |
Using two different FLUENT versions!
Rep Power: 16 |
I have used FLUENT version 14.5 to predict the convective heat transfer coefficients of bricks located in a wind tunnel and I have got certain values. Then when I have used another version of FLUENT which is "18.2", I have got different values of convective heat transfer coefficients. Is this normal? If no, what is the problem then? Issa |
May 9, 2018, 23:45 |
Lucky
Rep Power: 66 |
Yes it's normal. But how different? I honestly can't keep track anymore of all the tiny under-the-hood changes over the years.
What you should do is load only the data file (without doing any iterations) in v18 and see if the htc changed. |
May 10, 2018, 07:51 |
Rep Power: 16 |
Many thanks Lucky Tran for your reply.
The difference ranges from 1-20% which depends on the location of the brick in the wind tunnel. |
Abaqus - Fluent Coupling WITHOUT MPCCI | s.mishra | FLUENT | 1 | April 5, 2016 06:47 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
Using compiled UDF:s in different Fluent versions | S H | FLUENT | 1 | September 12, 2007 03:40 |
