August 20, 2019, 01:14 |
Changing Courant Number Changes Results ?
R P
Rep Power: 6 |
I am new to Fluent and would appreciate guidance from experts in here.
Bear with me on the detailed description and the efforts sustained on it. Was trying to simulate “Bladeless fan” in 3D. After trying for few simulations, couldn’t get to the default convergence level. This prompted us to move to 2D axi-symmetric model to check on the flow characteristics of the “Bladeless Aerofoil” fan profile and later use the learnings in 3D simulation. How wrong was the prognosis 😊 Details of the 2D Axi-symmetric model are given below. Crux of the challenge is that whenever Courant Number is changed, the whole results patterns change, as can be seen from the attached pictures on velocities. Realizable k-e turbulence model, with scalable functions, Coupled solver, nodal interpolations, all equations to be solved in second order, were chosen for quick turnaround. For the given model, if we change the courant number, to work on the convergence, the flow patterns change dramatically. Not sure as to which results are correct and which are not. And in all the cases in the pictures attached, the solutions are converged. Changing the inlet velocity does not seem to have effect on influencing the flow patterns. Can experts in here be kind enough to guide us as to what exactly is happening with the solution and which is the correct solution and why? How to work on solution convergence when controlling Courant number. By the way, in all the cases shown below, the courant number was changed at the start of the re-initialized simulation and “not” in between. Concern also about the behavior of residuals for different Courant numbers? Is it right / correct? Awaiting guidance Mesh size - ~ 80,000 nodes Quality - Skewness - Max 0.76 Method: Quad Dominant Edge Sizing: 1/2000 of Chord Length Inflation Max Thickness: 1/200 of Chord Length Leading Face: 25 times chord length Bottom Face: 25 times chord length Trailing Face: 35 times chord length |
August 21, 2019, 00:53 |
R P
Rep Power: 6 |
Good Day Everyone,
Any guidance on resolving the issue will go a long way in a better understanding of Bladeless Fan Flow Appreciate your help |
August 26, 2019, 04:51 |
Between Co 50 and Co 25 the result changes look pretty drastic, so i would double check everything in terms of boundary conditions and models..
I'm not familiar with external flow simulations, it just my gut feeling that something major changed between the two simulations. Co 100 / Co 50 and Co 25 / Co 10 look like reasonable changes.. |
August 26, 2019, 06:10 |
Rep Power: 9 |
Results seems not converged, use hybrid or fmg initialization and run all cases again, wait until residuals not change too much. Hope this will help.
August 26, 2019, 11:12 |
#5 | ||
R P
Rep Power: 6 |
I was scratching my head when I saw the results. Not sure why it is happening. Still haven't been able to pin down the reasoning behind it. Quote:
Not sure how to take the Simulation on Bladeless fan forward. |
November 21, 2021, 23:50 |
Desh
Rep Power: 5 |
I know this is an old tread but, anyone got any suggestions why the results are drastically changing with the courant number? Thanks, Dasith |
November 23, 2021, 03:40 |
Lorenzo Galieti
Rep Power: 12 |
If you accept your results change until a certain limit by refining the mesh, then you should't have problems accepting your results change when you refine your time step.
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
[PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 07:18 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
