combustion does not work in my valveless pulsejet |
May 22, 2020, 07:55 |
Barcelona
Rep Power: 6 |
Hi everyone,
I am working in my valveless pulsejet simulation and I can't get the expected results: It seems that combustions does not occur, thus there are not pulses... I will explain what I have been doing for my set up, so if someone has any clue what the mistake might be, please comment below. I have done a 2D problem. Solver: Pressure-Based, transient, velocity relative, 2D Space Planar. Models: Energy, k-e realizable, Radiation P1, Species Non-Premixed combustion (c3h8: propane) BC: 2 fuel inlet: inlet mass-flow 0.1kg/s each; inlet: pressure inlet 0 pascal Gauge Total Pressure; outlet: pressure outlet 0 pascal Gauge Total Pressure; wall: stationary and with 20W/m^2*K of heat transfer coefficient (convection) Methods: Coupled Controls: I left the flow courant number predefined (200) and I lowered 0.2 every under-relaxation factor except the mean mixture fraction and variance. Initialization: Standard, compute from all-zones in order to establish a mean mixture fraction of 1, temperature of 1600K and a 5m/s x-velocity. It was thought to start a simulation from a previous combustion. Calculation: time step size: 0.0001s, Max iteration/Time Step: 20 I think the mesh is not a problem. As it is a big surface I will update 3 differents pics so you can give your opinion: https://ibb.co/9G06PpD https://ibb.co/Nj18dv8 https://ibb.co/F3TsgTW I am also sharing the animations I have obtained of temperature and velocity so you can see how the propane is mixing properly but (VIDEOS UPDATED OF LAST SIMULATION) https://drive.google.com/drive/folde...9h?usp=sharing Pease, if you could help me it will mean so much as it is part of an important personal project Thanks in advance to everyone taking their time Last edited by jabuor; May 26, 2020 at 12:29. |
May 22, 2020, 14:50 |
update
Barcelona
Rep Power: 6 |
I am simulating again but with the only change on the combustion parameters. Now I have chosen species transport and selected the Finite-Rate/Edddy-Dissipation on Turbulance-Chemestry Interaction.
The inicialization is the same but now I have patched most of the combustion chamber in order to decrease the pressure (-5000 Pa) and create compression. I attach the pictures of the patching. https://ibb.co/F0NT0kC https://ibb.co/C0WkgH0 |
May 26, 2020, 09:25 |
Density
How are you modeling the density of the mixture?
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 26, 2020, 09:36 |
Barcelona
Rep Power: 6 |
In the species transportation method I picked the propane-air mixture but I did not model any density, probably predefine. But as I read in different pulsejet posts it is normally used non-premixed combustion models and in those I think you can't model the density of the mixture. I really don't know what I am doing wrong.
May 26, 2020, 09:39 |
Density
Until and unless you use real gas models, user has control over density method to be used. You need to use ideal-gas for pulse jet.
May 26, 2020, 11:18 |
Barcelona
Rep Power: 6 |
For the non-premixed combustion the density was selected from the pdf created. So I believe I have to change pdf to real-gas-soave-redlich-kwong. I will try again Thank you
May 26, 2020, 11:19 |
Density
If density is also coming from pdf table, then let it be as it is. Real gas is not easy to converge.
May 26, 2020, 11:36 |
#8 | |
Barcelona
Rep Power: 6 |
UPDATE: the last simulation I obtained combustion and pulsation but in the inlet area and the gases were not eject from the outlet. I used hybrid initialization and PISO scheme. Also I diminish the initial temperature of the whole pulsejet to 1000K and I set 0.01kg/s for the inflow mass of fuel. You can see the animations of temperature and velocity in the videos of the link: https://drive.google.com/drive/folde...4ToB7br-_4Re9h |
ansys, combustion, fluent, pulsejet, valveless |
Non premixed combustion - combustion chamber pressure | Gadders | FLUENT | 2 | January 14, 2020 14:28 |
Valveless Pulsejet | andreia_melo | FLUENT | 2 | August 8, 2018 10:51 |
A role of combustion modeling in flow solver? | Yoon | Main CFD Forum | 0 | November 26, 2006 12:00 |
Multiresolution + Turbulence + Combustion | Raul | Main CFD Forum | 0 | March 18, 2005 07:53 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
