Question regarding viability of Fluent for use case
Old   June 22, 2022, 03:01
Exclamation Question regarding viability of Fluent for use case
Sultan Islam
EternalSeekerX is on a distinguished road
Hello everyone,
So I am working on a multi-level model for a water network (like a house or a mall) using both Ansys Fluent and process software called Aspen Hysys. The idea is to use fluent to figure out flow conditions in a network and then use Hysys to do LCA, etc.
Currently I am working with example model geometry for tanks, pipes and ndoes (think faucets, toilets, etc).
The issue here is that I only have information regarding usage at ths node, so outlet conditions for mass flow rate. I want to be able to use that to work backwards down the network to the main tank (our first component) which we have inlet velocity value. I am wondering if its possible for Fluent to calculate inlet flow conditions given only outlet conditions?
For example, a faucet I know the coldwater and hotwater inlet temperature, I know outlet velocity and pressure (it would be ambient so 0 gauge pressure). What sort of boundary conditions should I use at the inlet so I can find the proper inlet mass flow rate and/or velocity?
After that I would like the extrapoloate the same method to distribution pipes all the way back to the main tank. Is this feasble with Fluent?
Thank You
EternalSeekerX is offline   Reply With Quote
Question on relative velocity profile (case dispersed oil/water in vertical pipe) mariem rezig CFX 1 October 7, 2021 16:49
Fluent Case and data file read very slow sumedhjain FLUENT 0 September 6, 2017 10:16
Multiple fluent case files in a single frame (Unsteady) arunraj Tecplot 0 June 29, 2016 09:30
Fluent case to OpenFOAM conversion umichsct OpenFOAM 4 April 23, 2011 14:59
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
