Importing Acis file to gambit
Old   June 21, 2001, 21:51
Default Importing Acis file to gambit
Habib
I am importing an Acis file to gambit (1 volume, 400 surfaces). Once I delete the volume I can never create a real volume again from the same surfaces. I am getting the following error message:
Acis error 601: Ray test failed to find intersection
I don't want to use the virtual option because Boolean operations can't be used any more especially the virtual volume can't be converted to real one without using map mesh.
Anyone can help?
Regards
Old   June 21, 2001, 22:00
Default Re: Importing Acis file to gambit
Trac
Have you tried using "heal surfaces"?
Old   June 24, 2001, 21:59
Habib
When I tried to heal the surfaces I got the same message as before
Old   June 24, 2001, 22:48
Trac
Do you need to delete the volume?! Is it possible to change the file outside of Gambit and then import it? Can you break it up into smaller volumes to work out where the problem area is?
This is going to sound completely stupid, but seriously, this has worked for me before, especially in import situations. Try copying the surfaces to another part of the screen, like translate everything 100 to the left or something.
Trac
Old   June 25, 2001, 00:06
Habib
I am trying to recreate the volume and smooth the bad surfaces using solid work package
Regards
Old   June 25, 2001, 05:19
Alain
If you are using solidworks try to export your cad as parasolid rather than ACIS.
parasolid is the native format of solidworks and give a smoother and a better geometry then imported in Gambit.
Best regards
Alain
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
Importing iges file Gambit error piyush FLUENT 2 April 28, 2006 08:42
importing solidworks2003 file to gambit 1.2 utku FLUENT 3 June 3, 2004 04:13
