3D unconfined sphere
Old   July 10, 2007, 04:46
Default 3D unconfined sphere
Kevin
Dear I'm simulating the low Reynolds number flow past an unconfined sphere. The solution for Re = 25 was converged to the experimental results with only 2% error. This means that the mesh resolution and configuration are both correct. But when I run the simulation for Re = 0.5 using similar schemes that were used for the mentioned Reynolds number, the downward trend of continuity residuals go into a stall. The minimum drag coefficient, that is attainable after checking a large group of FLUENT's provided schemes, is equal to 98 while the right answer equals 48 (about 100% error). I donÃÕ know what is the problem? I shall be greatly indebted to you if you help me to override this.
Thanks Yours respectfully
[snappyHexMesh] Meshing a sphere with snappyHexMesh Cyberholmes OpenFOAM Meshing & Mesh Conversion 2 July 19, 2011 16:46
Coanda effect, condensation on sphere technophobe Main CFD Forum 4 February 17, 2010 10:04
3D unconfined sphere in stokes regime Kevin FLUENT 1 August 4, 2007 11:48
CFX analysis of a sphere - drag too low Rob Findlay CFX 6 March 26, 2007 10:11
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
