December 7, 2008, 21:15 |
Cannot mesh volume
Hi, can someone help me please. I am currently on a project to model a bio reactor. Basically I have a L pipeline channeling the inlet to the vessel, and have 2 pipes to reject whatever effluent. I have split the volume of the reactor with the inlet pipelines, and try to mesh the volume of the reactor. and Gambit shows an error, "volume could not be meshed without face succesfully meshed" and "Meshing volume aborted due to poor face mesh quality". Does this means that I have to mesh the face before I mesh the volume. If so, which face I have to mesh.
Can anybody tell me what is difference between merge and unite? Thank you. Wendy Tjan |
December 8, 2008, 05:44 |
Re: Cannot mesh volume
If nothing works, you can opt for a tet mesh. Or else you can split the volume into many parts and mesh individually.
December 9, 2008, 00:36 |
This error message says that you have a small edge or something like that which generates a poor surface mesh. The volume mesh will crash becaus of the poor surface mesh. Try to examine the surface mesh (2d), and observe where is the worse cells.
December 9, 2008, 22:57 |
It could be that you have some unmeshed face. If that is the case, while doing a volume mesh, gambit tried to mesh the face with the interval size/count that you have specified for the volume mesh. This leads to a conflict.
December 11, 2008, 06:03 |
I can mesh for you
[Netgen] Volume mesh instead of surface mesh | phan | OpenFOAM Meshing & Mesh Conversion | 4 | October 18, 2009 17:17 |
mesh algo for volume mesh in star ccm | rohit | Siemens | 1 | August 8, 2008 20:44 |
Help needed to mesh a volume... | Cyril | FLUENT | 0 | July 18, 2007 07:59 |
Volume mesh problem_bis | Christophe | FLUENT | 0 | June 6, 2006 09:25 |
mesh a complex volume with different mesh | Nico | FLUENT | 2 | April 29, 2005 09:45 |
