Help: floating pressure, multiphase, closed domain |
August 25, 2009, 21:22 |
muhammad irham mahfud
hi every body..
i want to know pressure rise in a closed domain cause heat flux in the system, my domain is multiphase contain liquid nitrogen and air. i used mixture model multiphase system with floating operating pressure.. my problem is the iteration start error after 750s. if you have same case or hint, please share to me.. below i show my general step of my simulation thanks in advance general Pressure based Transient Gravity (9.82 m/s2) Model Multiphase mixture model Energy equation(yes) Material Primary : air ( density: ideal gas, Secondary : liquid nitrogen (UDF) Phase Interaction: mass transfer evaporation (Tsat: 77.35K) Boundary condition Heat flux : 2 W/m2 Floating operating pressure (yes) Solution method Scheme : PICO Solution initialization Compute from : wall Initial temperature 70 K Volume fraction : 0.5 |
September 24, 2009, 03:38 |
why the iteration start divergence in the middle of running..
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
capillary pressure in multiphase model | Shekhar | FLUENT | 3 | March 23, 2004 02:28 |
pressure distribution in closed enclosure | Prasanth | FLUENT | 2 | February 18, 2004 05:36 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
