Home > Forums > General Forums > Hardware
Segmentation error in OpenFOAM after RAM upgrade
Old   August 26, 2013, 03:36
Exclamation Segmentation error in OpenFOAM after RAM upgrade
anonymous
Man Yue is on a distinguished road
I am using OpenFOAM 1.7.0 on a notebook. The notebook has originally 2GB of RAM. I upgrade the notebook by adding another 8GB RAM into the notebook. After adding, I run decomposePar. After running decomposePar(i.e. I see the end for decomposePar), the computer shows Segmentation error as follows:
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 cfree in "/lib/libc.so.6"
#4 Foam:olyMesh::~polyMesh() in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
in "/opt/openfoam170/applications/bin/linux64GccDPOpt/decomposePar"
#6 __libc_start_main in "/lib/libc.so.6"
Segmentation fault
Why is it and how should it be solved? The notebook and linux itself has no difficulty in detecting the RAM (the linux system shows 9.7GiB).
Man Yue is offline   Reply With Quote
Old   September 14, 2013, 13:25
Retired Super Moderator
Bruno Santos
Greetings Man Yue,
I'm a bit late to answer, but it's possible that either the RAM has issues or misconfigured in the motherboard's BIOS.
As for making sure the RAM is OK, you can use Google's stressapptest program, as I for example mention here: http://www.cfd-online.com/Forums/ope...tml#post404995 post #5
Best regards,
Bruno
openfoam, ram, segmentation fault, upgrade
Memory protection in OpenFOAM / combinig with FORTRAN botp OpenFOAM Programming & Development 2 February 15, 2016 12:25
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 15:06
Ram, cache and cpu upgrade help zonexo Main CFD Forum 14 January 24, 2007 09:05
Fluent and RAM Speed Allan Walsh FLUENT 6 April 21, 2004 16:08
