Overture Installation for Oceanwave3d
Old   July 14, 2014, 08:39
Default Overture Installation for Oceanwave3d
andrew odonnell
andr5w5 is on a distinguished road
Hi there,
I'm very new to linux and CFD and I am trying to install the overture based software OceanWave3D (http://www.sdwed.civil.aau.dk/Software/). I have been following these instructions , http://mabouali.wordpress.com/2012/0...talled-ubuntu/, to install overture however when I try to install overture and type the "make" command I get this error at the end of the compiling,
make[1]: *** [DataBase_date] Error 1
make[1]: Leaving directory `/home/andrew/Downloads/Overture.v25/DataBase'
make: *** [all] Error 2
I believe I've installed all the other programs correctly and amended the 'defenv' file accordingly. Can anyone help me with this error? I've probably left out some information that is needed to solve this.
Many thanks,
Andrew
andr5w5 is offline   Reply With Quote
Old   July 14, 2014, 16:36
som87 is on a distinguished road
Normally if your version of A++ and P++ is not compatible, you can get such error (Database for Overture)
Unless you explain a bit more, it's tough to say something else.
Please check again if you have the proper A++and P++ package installed (specially A++ unless you are actually using P++)
Best wishes,
Somdeb Bandopadhyay
som87 is offline   Reply With Quote
Old   July 14, 2014, 17:51
andrew odonnell
Thanks for the reply,
I haven't installed P++ so I am just using A++. How would I check if A++ is installed correctly? I just followed the instructions on the link in my original post.
Old   July 14, 2014, 18:12
As far I remember, overture's official website used to distribute a package of A++ with every version.
In any case, as long as you get database error, you can more-or-less conclude that there's a problem with your A++ library..(it is the database for Overture as you can already understand).
Try to re-install A++ in case you need
PS: I used CENT-OS, so if there is some typical Ubuntu problem, I cant be of any help...apologies :s
Best wishes,
Somdeb Bandopadhyay
Old   July 16, 2014, 04:57
andrew odonnell
Thanks for your help, the directory for the environmental variables for A++ in the defenv file was slightly wrong and it has now compiled.
Andrew
Old   July 16, 2014, 06:22
Gratz
(^_^)
Best wishes,
Somdeb Bandopadhyay
[foam-extend.org] A smooth installation of foam-3.0-extend on OpenSUSE 13.1 64-bits cookcaptain OpenFOAM Installation 7 May 26, 2015 11:22
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Installation problems indy OpenFOAM Installation 7 April 3, 2009 09:40
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 13:29
