How to construct the variable on faces of control volume
Old   November 5, 2014, 04:19
Default How to construct the variable on faces of control volume
ZhengJJ
fengyunmanbu is on a distinguished road
Hello CFD-Onliners~
I am currently studying to program a finite volume solver in cell centered scheme. When calculate the gradient in cell by the method metioned as below.
http://www.cfd-online.com/Wiki/Gradient_computation
It's need to know the variables on the faces of control cell.
May I ask how?
ps: Is there any books or someting else can be recommended
fengyunmanbu is offline   Reply With Quote
Old   November 5, 2014, 07:26
Parth Thaker
Parth04 is on a distinguished road
advection schemes are used for finding values at face from values at cell centers . . .
referances - book of anderson, book of patnakar
Parth04 is offline   Reply With Quote
Old   November 5, 2014, 20:53
ZhengJJ
thank you for your reply
I find two method
First: set the average of values at two adjacent cell centers as the values at their interface.
Second: calculate the values at grid point by weighted mean of central values, then average the values at points of face as the value of the face.
The first one seems simply, but which one is better?
Old   November 6, 2014, 04:11
Parth Thaker
there are many mathods, cental differencing (the first u said that) , first order upwind , second order upwind, QUICK, it depends on your problem and solver to select the method
Old   November 6, 2014, 14:04
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
There is a clear difference between computing the face values for the convective fluxes and for the gradients. Simply because the former usually require the latter.
Thus, we speak here for the gradients (and not the fluxes).
According to the Fluent references, the second method (node based) is superior to using a simple average of adjacent cell values. Actually, i tested this one on my own and found it also inconsistent on some tetrahedral grids.
If you don't want to go node based (which indeed is quite involved), you can iterate on the cell based one. You add to the simple mean the contribution of the gradients from both cells. At the first iteration such contributions are null. Then they build up with the iterations. This does not necessarily converge (because the resulting computational stencil is growing) but 2-3 iterations will improve the basic method.
My personal experience is to use:
- least-squares with two cell layers (or maybe one by carefully playng with a weighted least squares)
- Radial Basis Functions. Interpolate one or two cell layers around your cell with a RBF and take its analytical derivative. Its simpler than the least squares (once you have everything set up) and can give you much higher accuracy with, possibly, only a minor overhead (they both use matrices to compute the final derivative).
sbaffini is offline   Reply With Quote
gradient fvm
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
