August 9, 2017, 15:24 |
Preprocessor that is most simialr to Gambit.
nm
Hi guys,
I am curious if there are any preprocessors today which are very much like gambit. The major reason having the functionality to move the mesh around and the overall flexibility and control we have. Especially, easily manually sweeping 2-D meshes into 3-D. I have only tried workbench (and for a considerable time) and found it to be lacking in several arenas. I am curious if there are any meshers which offer the functionality of gambit. (pointwise, ICEM- i know the old ICEM was time consuming too not sure about newer versions, or ANSA?) Thanks. |
August 10, 2017, 11:04 |
Lucky
Rep Power: 66 |
If we are talking about hexahedral grids:
ICEM has my #1 vote for most similar to Gambit. Try GridPro. It is more automated (because that is their selling point) and does not give you full manual control. GridPro doesn't do tets. They have added tools for mesh extrusion in v6 because it was a highly requested feature. Pointwise would have been my third choice, but I have not used it in almost a decade to know where it is at now. |
August 10, 2017, 11:41 |
I tought it was this one:
http://www.csimsoft.com/trelis-cfd They (GAMBIT and Trelis) are both branched from the same root, CUBIT (according to http://www.csimsoft.com/about.jsp). |
August 10, 2017, 16:13 |
nm
Okay.
Even the latest version of workbench is buggy and generally useless for complex CFD calcs. Creating mesh is another solution process rather than "pre-processing". I will check out both of your suggestions. |
gambit 2.4.6, meshing 3d, preprocessor |
Edges numeration issues in Gambit | Fidippide | FLUENT | 2 | October 6, 2015 10:13 |
[ICEM] Different meshes from ICEM and GAMBIT | Mojtaba.a | ANSYS Meshing & Geometry | 9 | March 30, 2013 02:42 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
