Simple question regarding basic APDL command snippets and parameters
Old   February 26, 2018, 04:50
Default Simple question regarding basic APDL command snippets and parameters
NG192 is on a distinguished road
Dear Forum Users,
I have to solve a design exploration study which consists of a thermal and two mechanical systems.
The two mechanical systems are identical, except that one doesn't use the temperature field from the thermal analysis (no thermal load), and that different output values will be monitored.
My problem is that both mechanical systems has one input parameter which needs to be driven by the design explorer and have to be identical in every design point the design explorer generates (since the two mechanical systems are identical except for the temperature aspect). This input is a simple magnitude for a pressure load.
I assume this could be solved by adding a command snippet for any of the two mechanical systems which sets the pressure magnitude to the parameter value representing the pressure magnitude from the other mechanical system (named as P53 in the parameter set tab).
My problem is that I don't have any experience with command snippets and presumably I wouldn't be able to dig into the topic fast enough... I tried it for a couple of hours already and have to solve this asap...
Any help would be greatly appreciated.
NG192 is offline   Reply With Quote
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
Simple question about .res file livsviktiftflode CFX 0 February 24, 2016 11:13
[ICEM] Edge Parameters Question RodriguezFatz ANSYS Meshing & Geometry 5 August 15, 2013 10:13
A simple CFD code for teaching basic CFD? Christoph Lund Main CFD Forum 13 September 14, 2005 04:36
A simple question! gracesky CFX 1 October 19, 2002 07:38
