Upwind scheme blows up when encountered a peak |
March 6, 2018, 20:10 |
I am solving a nonlinear hyperbolic equation using simple upwind scheme with discontinuity in the solution. But when a peak occurred, the solution blows up, just as the one in the attached figure, the right-hand side peak keeps increasing until inf eventually. When I tried Lax-Friedrichs, it all went well: the peak reaches 100 and stop increasing, which is expected. Upwind is much more diffusive than LF, so I think this blow-up should not happened. But I really don't know why this is happening. Is it upwind invalid for this situation? Any thoughts? 1.jpg Thx. |
March 7, 2018, 03:45 |
Filippo Maria Denaro
Rep Power: 71 |
Provided that you are fulfilling the stability constraint, You have for sure a bug in the code.
March 7, 2018, 16:58 |
#3 | ||
On the other hand, I checked and checked my code, I don't see any bugs. The equation I am solving is , where, and c are constant, but varies with x. Anyway, denoting , than I write this code for upwind: where unew stands for the u for next time level, I don't know where it goes wrong. Codes for the upwind (for MATLAB): Quote:
March 7, 2018, 17:12 |
Rep Power: 71 |
The upwind criterion is applied considering the characteristic direction, therefore you have to consider both the signs of the advective velocity. Are you sure that your problem has always a positive advection component?
March 7, 2018, 18:12 |
Yes, the convective velocity will always be positive.
March 7, 2018, 18:31 |
#6 | ||
March 8, 2018, 04:15 |
Rep Power: 71 |
Ok, let me some time, I never solved numerically this equation, I will have a look. However, I suggest to write the code in terms of the FV formulation, computing first the fluxes and then performing the update.
March 8, 2018, 11:41 |
Rep Power: 71 |
I insert the plot into the code to see the evolution step-by-step. I see the left branch becoming a shock wave and the right branch becoming a rarefaction wave. The simulation run until a small wiggle is produced at the basis of the rarefaction wave, near the value u=0.
Therefore, I assume that your solution produces some very small negative value that will be amplified owing to the assumed positive upwind. That is a numerical instability. I suggest to translate the initial solution adding a positive constant (also simply 1) to avoid having small negative velocity. Otherwise, check the negative event and set the value to zero. I suggest also to replicate the case illustrated in the book of Leveque a page 206, you could also check for the source with the Godunov scheme. |
March 8, 2018, 17:11 |
#9 | |
2.jpg1.jpg I highlighted the negative velocity and some wiggle(I suppose). Are these what you mentioned? |
March 8, 2018, 17:21 |
#10 | |
Rep Power: 71 |
Just plot u at each time step and you will see creating a small wiggles at the expansion front (about x=30) that will be amplified. The shock is well resolved. Thus, check again your code for some bug. |
March 8, 2018, 17:26 |
#11 | |
1.jpg2.jpg If you do mean this one, I think this is what expected to happen, since the wave is kind of "congested" in this section. |
March 8, 2018, 17:27 |
#12 |
Rep Power: 71 |
Yes, it is.
Are you sure about the way you set the periodic BC.s? |
March 8, 2018, 17:36 |
#14 | |
Rep Power: 71 |
I don't know the physics of the problem but you should see a coalescence in the characteristic lines to generate a discontinuity |
March 8, 2018, 17:56 |
#15 | |
1.jpg2.jpg3.jpg The peak (or as you said, wiggle) at the most-right will gets thicker and thicker, eventually entire wave will reform into a higher, thinner square wave, comparing to the initial solution. The maximum peak should stop at around u=100, which will never generate negative velocity. But with upwind, I don't see "congestion" at x=30, so for this peak, instead of getting thicker, it gets higher and higher. This is what I am wondering about. |
March 8, 2018, 18:17 |
#16 | |
Rep Power: 71 |
Ok, the problem depends on the function v(x), it should be better described in the x,t plane by looking at the characteristic curves. As I wrote before, I never solved this specific problem that is slightly different from the example in the Leveque book. The rarefaction front should encounter a low or vanishing velocity in such a way to generate compression. However, I see that continuing the run, after some time the u plot shows negative values. Could you write me the initial condition u(x,0) and the function v(x)? |
March 8, 2018, 18:20 |
#17 | |
March 8, 2018, 18:43 |
#18 | |
March 9, 2018, 03:57 |
#19 |
Rep Power: 71 |
Well, I see that v0 produces a variation for x>=30 but the initial condition is upward. That makes me suppose that the starting of the compression region is downwind with respect to the used stencil [i-1,i]. Somehow, that does not respect the upwind criterion. I am not sure if this is the problem, just check the sign of the characteristic. This problem has differences from the standard non-linear Burgers equation. |
March 9, 2018, 13:52 |
#20 |
Rep Power: 71 |
I wrote few lines about your problem, I suggest to read 16.4.1 and 16.4.2 in the book of Leveque. You will see that the definition of the upwind criterion is quite more complex than you supposed.
hyperbolic functions, lax-friedrichs, nonlinear equation, upwind schemes |
bounded Gauss upwind Scheme | deepinheart | OpenFOAM Running, Solving & CFD | 1 | February 23, 2015 05:57 |
Implementation of 2nd order upwind scheme | jaason | OpenFOAM Running, Solving & CFD | 4 | February 6, 2015 17:40 |
2nd order upwind vs 2nd order upwind!!! | Far | Main CFD Forum | 7 | March 14, 2013 12:29 |
Use of upwind scheme for interpolation of u/v | quarkz | Main CFD Forum | 6 | August 30, 2011 04:10 |
2nd order upwind scheme (Fluent and CFX) | Far | FLUENT | 0 | May 22, 2011 01:50 |
