Internal 2D steady simulation results depend on turbulence models strongly. |
Březňák
Rep Power: 4 ![]() |
Internal 2D steady simulation results depend on turbulence models strongly. You can see the geometry in the attachment. Let's think the flow direction is in plus. Flow is incompressible. y+ on the wall is between 1 and 2. The used solver is FLUENT and the residual targets are default values. 1. For case of RMS: >> the velocity x-component in plus is dominant near the wall in Zone 1. >> I can detect relatively huge detachment(Correct English word for Ablösung?) in Zone 2. 2. k-omega-SST: >> the velocity x-component in plus on the wall is smaller than the case of RMS in zone 1. >> Detachment in Zone 2 also smaller than in the case of RMS. 3. k-epsilon: >> the velocity x-component in plus on the wall can be found only in the half length of zone 1. >> Detachment in Zone 2 is barely to detected. For each three models, I also tested different meshes (coarse, moderate, dense), but the results seem like that turbulence models have more effect on the different flow results. In the case of k-omega-SST with more dense mesh, the results show bigger detachment in zone 2 than results with k-omega-SST and coarser mesh. Which turbulence model will be best in this problem? With kind regards Breznak Last edited by breznak; May 2, 2022 at 07:21. Reason: geometry |
Filippo Maria Denaro
Rep Power: 64 ![]() ![]() ![]() |
Could you show the comparison of the results (for example the 1d velocity profiles) for all cases only for the finest mesh (number of final nodes in x and y?)?
If you are working without wall-modelled BCs you should use some more nodes at y+<1. |
#3 | |
Rep Power: 13 ![]() |
Březňák
Thank you so much for your answer, but unfortunately I cannot upload detailed geometry in public.
Display Modes | |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 02:47 |
Backup results in steady simulation | Li | CFX | 0 | July 9, 2007 05:39 |
Why Turbulence models are not universal. | Senthil | Main CFD Forum | 4 | July 5, 2000 04:34 |
Turbulence Intensity Vs CFD Simulation | Apple L S Chan | Main CFD Forum | 3 | December 15, 1998 17:28 |
