November 27, 2022, 13:18 |
Numerical diffusion, tet, hex, poly mesh
Rep Power: 17 |
In many references from proponents of polyhedral meshing it is often said that polyhedral cells have 6 preferred directions (for a 12 face polyhedral cell). A hexahedral cell has 3 and a tetrahedral cell has zero. This is then used as an argument for numerical diffusion (or minimisation of). I do not understand how this works. It seems to me that while a polyhedral cell may have 6 preferred directions it will then also have 6 directions that may be oblique to the flow, which of course will cause numerical diffusion. As I understand it, the only way of avoiding numerical diffusion is across cell faces that are normal to the velocity vector. Triangles can be used for this, just as well as quads, but most text-book examples use an unstructured triangular mesh as comparison compared to a structured quad mesh and therefore it seems that triangles cannot be used. As a comparison, figure 1 is from ANSYS best practice guidelines, and figure 2 is just a structured triangular mesh with the same type of comparison (cell values plotted, not node values). Information propagates in small wiggles for the triangles as the cell centers are not aligned perfectly as for the quads, but that does not matter since the information transport is contained in the same quad that was split to create the triangles. Anyways, for the general case with a fully unstructured mesh it may be easier to have parts of the domain aligned with a certain flow direction if quad/hex mesh is being used, so perhaps the text-book examples are OK. However, I still do not understand the argument about "preferred directions" when it comes to polyhedral cells. The best argument for polyhedral cells is that we have more neighbours when calculating gradients, but that has no connection to the numerical diffusion. What do you think, do you have any better explanation for the argument of polyhedral cells' preferred direction?
"Trying is the first step to failure." - Homer Simpson |
November 28, 2022, 07:51 |
Filippo Maria Denaro
Rep Power: 71 |
"preferred direction" is somehow associated to structured grids and flow aligned with some coordinate direction.
However, I would consider the term "numerical diffusion" depending on the type of scheme, not the type of grid. A flow aligned along a structured grid direction can reduce the numerical diffusion of upwind but you can have also multidimensional FV reconstruction on unstructured grids with low numerical diffusion. |
November 28, 2022, 07:57 |
#3 | |
Arjun
Rep Power: 34 |
The main thing with polyhedrals is that the gradients calculated are more accurate and have much lesser control volume shape dependency. Any good numerical scheme in unstructured meshes depends on accuracy of these gradients.
This is why it is not straightforward to compared hex and polys. There will be cases where polys outperform hexes. Quote:
November 28, 2022, 09:45 |
#4 | ||
Rep Power: 17 |
It is interesting that you mention structured grids as an important aspect of numerical diffusion as opposed to cell types. As far as I can tell, there is a lot of discussion regarding cell types floating around (as is evident by the ANSYS slide i attached previously). They do the "hex vs tet" comparison, while it really should be a "structured vs unstructured" comparison. Quote:
Perhaps you mean that the numerical diffusion question is a non-question (to which I would probably agree) regarding poly vs hex vs tet? I just wonder why many sources list "preferred directions" as something positive when comparing these three cell types.
November 28, 2022, 10:42 |
#5 | |
Arjun
Rep Power: 34 |
It is highly connected to numerical diffusion that is associated with advection term that you are considering here. There are many ways it can show up one of them would be to kick in the gradients limiters when the gradients shall not be limited at all. Better gradients construct better values at the faces resulting in less numerical diffusion. |
November 28, 2022, 11:43 |
#6 | |
Rep Power: 17 |
Or perhaps I misunderstand your reply in that you mean that numerical diffusion is mainly caused by the gradient calculation? In this case I can show several counter-examples where the numerical scheme has absolutely no effect on the numerical diffusion (my example above was made with UDS and it will produce the same result using 2nd order UD). So I would argue that alignment is the main driver, and in absence of alignment then the scheme becomes more important to reduce numerical diffusion.
November 28, 2022, 12:04 |
Rep Power: 71 |
Again, "numerical diffusion" is a nomenclature due to the appearence of a diffusion-like term in the modified differential equation, no matter about the type of grid. You need to introduce the scheme to talk about that!
In commercial codes, like Ansys, this nomenclature is used in a misleading way when some advices to users are done about the choice structured vs unstructured grids. That is due to the fact that the choice for the discretization is constrained by at least second order scheme for transient. And such discretization have nothing to do with the modern multidimensional discretization. Since you are talking about direction of the flow compared to the normal vector unit to the face, I assume you are considering FVM, not FDM. Remember that the update in a cell is due after doing the sum of contribution of the flux along each face. Thus, is not sufficient to consider only the condition for a single face, you should ensure that the flow is aligned to the normal vector unit both for an inflow and outflow faces. Last note, consider a standard structured grid with a non-uniform step. Write a FD "central" derivative and evaluate the modified wavenumber. You will see the appearence of a imaginary part, that is a dumping in the amplitude, like a numerical diffusion. In this sense, despite the fact that the structured grid is aligned that introduces also on the central scheme the numerical diffusion. |
November 28, 2022, 12:39 |
#8 | |
Arjun
Rep Power: 34 |
First order upwind scheme is a special case where gradients are zero. Second order upwind scheme is better and now gradients are not zero. Third order upwind scheme is more accurate than the other two and hence has less numerical diffusion. This scheme has more gradient terms. (this is assuming ideal and most accurate gradients). Now with wrong and bad gradients both second order and third order schemes could be worse than first order upwind and may (if not wrong) also exhibit numerical diffusion efforts. |
November 28, 2022, 14:52 |
#9 | |||
Rep Power: 17 |
First, thank you for having this discussion, it is interesting!
I would argue that numerical diffusion is the erroneous propagation of (advection) information on a fixed eulerian mesh. I think it is unnecessary to talk about the differential equation since we can describe the phenomenon from the flux balance directly, just using numerical reasoning (as opposed to physical reasoning ). Basically, if we have no means of moving information in directions other than the face normal direction (of any face) then we will always cause some numerical diffusion unless the advection velocity is either parallel or orthogonal to each of the faces of the cell. There is a caveat though; as I showed in my example with the triangular mesh, it is fully possible to have zero diffusion even though this constraint is violated. This is because the numerical diffusion caused when leaving the main diagonal (flow vector is not parallel to the face vector) is then corrected in the next triangle. Quote:
PS I do think hexagons are good.
November 28, 2022, 15:47 |
#10 |
Rep Power: 71 |
Numerical diffusion is not associated to a propagation along a specific path-line as happens in convection but is isotropic. You have to consider the appearence also of more general numerical errors like the dispersion error.
As a more general comments, while the flow of momentum enters into a face of a FV it is simultaneously subject to the physical diffusion and pressure gradient. Thus, it is this kind of combination that has to be described. In my old experience I found good results on several types of unstructured grids, see Sec.4.1 here https://www.researchgate.net/publica...cal_Simulation |
November 28, 2022, 16:18 |
#11 | |
Rep Power: 17 |
How does dispersion errors affect the choice of tet vs hex vs poly in terms of numerical diffusion?
November 28, 2022, 16:38 |
#12 | |
Rep Power: 71 |
Again, without talking about a specific scheme, an aswer to your question has no practical meaning. Numerical diffusion (that, differently from the physical one, can be also non isotropic) is associated to the presence in the modified equation of second derivates while dispersion is associated to third derivatives. |
November 28, 2022, 21:58 |
#13 |
Lucky
Rep Power: 66 |
In the context of implicit FVM, when you write down the discretized equations with the discretization schemes, there are terms that are diffusion-like (they look exactly like diffusion) except they don't have their origins in physical diffusion and this we call numerical diffusion. You can appreciate this much easier if you write down the discretized equation using symbols instead of looking at pictures of solved velocity fields. The schemes cause the diffusion so you cannot just simply ignore all the math and say we don't need to talk about differential equations. The mesh also enters here in a generic way since the discretized sccheme will take displacements from mesh. Still there is much more analysis needed to prove why poly vs hex vs tets is better/worse for numerical diffusion for a general class of expected flow.
The easiest example is to apply upwinding to a pure advection equation and write down the symbols by hand. Then you see that discretized (pure advection) equation becomes an advection-diffusion equation. If you need help understanding why numerical diffusion is isotropic I suggest doing a 3D advection equation in vector notation. The equation will be identical for 1D and 3D if you use vector notation and there you can plainly see that it is indeed isotropic. Not all numerical errors are numerical diffusion. Some common schemes produce spurious oscillations (2nd order upwinding or central difference for example) produce errors that are anti-diffusive (overshoots and undershoots). And to explain what is numerical dispersion: anything that isn't already named like numerical diffusion, whatever is left that is an unnamed error, is numerical dispersion. |
November 29, 2022, 03:30 |
#14 |
The simplest example I can think of is linear advection with the FTUS scheme in 1D and uniform grid. What you get is just function of the Courant number and ranges from numerical diffusion to exact transport to instability.
So, it is not, indeed, just about the mesh and flow direction. |
November 29, 2022, 04:14 |
#15 | |||
Rep Power: 17 |
Thank you @arjun, @FMDenaro and @LuckyTran for your input. I hope my answers are not coming off as rude. I think this is interesting and even though I do not agree with your way of explaining why "preferred direction" of poly cells are common in comparisons between tet vs hex vs poly, I now have a few additional comments/questions regarding numerical diffusion, since this is the direction the thread took.
But I have said UDS several times. Please explain it using UDS or pick the scheme you like. Quote:
Welcome LuckyTran, we usually disagree, let's see how this goes! I am not ignoring the math, I just gave an example that really does not need any differential equations. I have full appreciation for the differential equations, especially if we use FDM, but in many cases for FVM they are not needed in order to explain phenomena (imho). I thought it was obvious from figure 3 what I meant. You can see that the information propagation on the triangle mesh is actually causing numerical diffusion, which is corrected thanks to the structure of the mesh. Information (stored at the cell center) is not traveling along the advection direction, but is wiggling up and down. The wiggles cancel out with the current mesh and as such there is no numerical diffusion. I am assuming a steady-state here and transmit information in an iterative manner, but we could discretize time as well to explain similar phenomena in transient calculations. I also added an example of numerical diffusion, using this reasoning, in the hexagonal example. Here information travels to nodes that are not on the trajectory that any particle starting at the initial node would actually land on if the advection scheme was correct (in reality we obviously need to imagine particles originating from the entire volume of the cell). This causes a smearing of information that I attribute to numerical diffusion. It is also clear that larger cells cause more numerical diffusion, using this reasoning. I could draw another figure where a color function is advected on a mesh to make it even more clear, but I think figure 3 should be clear enough. Quote:
Thank you, this is answering my original question. So in conclusion; any text which referees to "preferred directions" as a strong point of polyhedral cells is just marketing talk. They should really stop at "more neighbors which helps with gradient calculations".
November 29, 2022, 04:16 |
#16 | |
Rep Power: 17 |
It depends how you discretize time. You can imagine a case where we discretize space-time and solve this as any other 2D problem. Then you can use different cell-shapes in time.
November 29, 2022, 04:33 |
#17 |
Rep Power: 71 |
I think you are mixing several issues of the numerics.
What you call "numerical diffusion" when talking only about the grid is better analysed if you consider the grid resolution for high/infinite gradient. What happens if you sample an initial Heaviside function on a grid? There is no way to describe exactly the singularity, you have only the information that you have the value 1 on a node and 0 on the next. You have lost any information between 1 and 0 and that is consistent to the fact you accept a regular function between the two nodes. This is a sort of "numerical diffusion", without talking about any scheme. But, formally, this is the sampling error you have due to the Nyquist theorem. Then, if you consider a physical reasoning in a FV, also at a steady state, the balance of the fluxes means nothing. You can have a balance also if you have convective and diffusive fluxes. In this old paper https://www.sciencedirect.com/scienc...21999179901426 you can see a proposal for a multidimensional scheme with an anisotropic diffusion with the goal of reducing the numerical viscosity of the donor cell. |
November 29, 2022, 05:05 |
#18 | |
But that's not the point. What I wanted to highlight is that you can have the simplest convection scheme EVER on the simplest grid arrangement to behave in whatever way you like just using a different time step (which in your 2D view would be the 2D grid aspect ratio). So, the point is, numerical diffusion is either there or it isn't. Flow alignment can, indeed, remove ADDITIONAL numerical diffusion terms, but not change the nature of the scheme. In general, flow alignment is related to the fact that certain solution derivatives are 0 in a certain frame of reference. As a consequence, the resulting terms in the Modified Differential Equations are locally 0 and the resulting error, which is still dependent on the scheme, is lower. Hexa grids are naturally inclined to this (pun intended). Polyhedral and tetrahedral grids are not, to the best of my knowledge. Where polys should be better than tetra (but not properly aligned hexa) is error cancellation on opposite faces and, as mentioned by arjun, gradient computation. But, honestly, I haven't seen a verified statement for none of them. After all, polyhedral grids are mostly an exclusive of commercial grid generators. |
November 29, 2022, 05:36 |
#19 |
Lucky
Rep Power: 66 |
There are certain advantages to polyhedral and hexahedral meshes over tetrahedral meshes, it is not just some stupid marketing guy that came up with it. But you need to first understand what is numerical diffusion and what is not.
Do a taylor series about the face flux Upwinding means we approximate the derivative as such Therefore when you solve using this upwind scheme, you don't solve for the true velocity u, but a modified velocity v which contains numerical diffusion because If you want to see numerical dispersion then do the taylor series to the next higher order term (hint: keep the 3rd order derivative). Here you see different grids that weakly produce different v's even without needing any actual gradient calculation for the same prototype upwind scheme will have differing amounts of numerical diffusion, it just depends how close v is to the actual u. Not shown here is that a tet grid vs a hex grid vs a poly grid, one is more accurate than another. I've shown it for 1 face flux. You need to sum the fluxes over all cells. Here is where the cell type matters because you can have error cancellation depending on the cell type and the scheme. |
November 29, 2022, 06:07 |
#20 | |||
Rep Power: 17 |
Trying to reply to portions of the text since there are many new concepts being introduced to the discussion.
Yes, FTUS can be seen as a (in context of FVM) discretization of space-time where we use a downwind approximation in time (for explicit treatment, for implicit treatment we use upwind in time). Normally we do not discretize and solve for space-time since that would force us to use an extremely expensive 3D calculation (3D space + time). Solving for space-time in 1D (1D space+time) cases is easy though. All such solvers would not step in time but rather solve as if the case is "steady-state". It is easy to see that you can create a space-time mesh that satisfies the Courant number constraint given by traditional analysis. Quote:
This may be the key point. Would you say that the triangle example above has numerical diffusion?
[ANSYS Meshing] Unexpected Transformation of Hex to Tet mesh. | Rajkool | ANSYS Meshing & Geometry | 0 | February 17, 2020 10:13 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[blockMesh] apparently the mesh doesn't want to be created in one direction | Maxime Thomas | OpenFOAM Meshing & Mesh Conversion | 1 | August 18, 2012 06:05 |
[blockMesh] BlockMesh number internal faces and boundary | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | December 13, 2011 05:36 |
hex mesh vs. tet mesh (for FEM solvers) | Sam | Main CFD Forum | 0 | July 1, 2005 15:11 |
