September 17, 2000, 22:04 |
Baldwin-Lomax model at Rotating coordinate
Hi everybody
I want to apply the bladwin-Lomax model in the case with moving and stationary wall at the rotating coordinate. I have some problems in calculating the vorticity, wall shear stress and wake velocity. If anybody konw the method, please let me know. thanks |
September 18, 2000, 01:06 |
Re: Baldwin-Lomax model at Rotating coordinate
(1). The book by David C. Wilcox, entitled "Turbulence Modeling for CFD" ,2nd edition, 1998, has a good chapter on algebraic models, which includes the Baldwin-Lomax model. Wilcox website can be found in the forum/resources section. (2). The ASME/ Journal of turbomachinery should have some published cfd papers using the Baldwin-Lomax model. It is a simple and widely used turbulence model. (with limitations, as usual)
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
Mixing model with rotating impeller problem | 201 | CFX | 10 | May 14, 2010 11:59 |
How to enforce positive values | Ning | Main CFD Forum | 10 | August 20, 2000 00:10 |
