What is the efficient scheme?
Old   January 3, 2001, 10:03
Default What is the efficient scheme?
Brayton
What is the efficient Navier-Stokes computational scheme? i.e., the largest time step that could be used?
Old   January 3, 2001, 10:58
Default Re: What is the efficient scheme?
Girish Bhandari
It depends upon the complexity of your problem. An Implicit Beam-Warming should give you fairly good results with higher CFL numbers.
Girish
Old   January 3, 2001, 12:01
John C. Chien
(1). When you are solving a transient problem, the un-steady equation is used. And you will be marching in time to solve the transient problem. (2). The time step used must be small enough to resolve the transient motion of fluid, because it is an initial value problem. (3). For steady-state problem, the equation will be independent of the time, and time steps. Therefore, there is no need to worry about the use of time step. (4). But, sometimes, it is possible to obtain steady-state solution by time marching. There is no guarantee that such approach will lead to a steady-state solution. (5). In this case, it is possible to increase the time step to reach the steady-state solution. The time steps used are no longer the real time steps. (6). Sometimes, there is additional stability limit on the time step used, in the transient formulation or scheme. (part of the problem comes from the truncation error or accuracy) In this case, the time step of the explicit method under the stability limit is linked directly to the physics (or accuracy) of the solution. As a result, the time step used must be relatively small in the marching methods.(explicit method) (7). For obtaining steady-state solution using a transient approach, implicit methods can be used to increase the time step (no longer the real time step) for stability reason.
Old   January 4, 2001, 11:46
Brayton
Thank you all!
Old   January 5, 2001, 15:36
Brayton
Thank you.
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 21:20
When to use upwind or central differencing schemes? quarkz Main CFD Forum 6 August 19, 2011 03:24
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 11:21
