Explain VOF Reconstruction Method
Old   September 20, 2001, 05:27
Default Explain VOF Reconstruction Method
Zi-Wei Chiou
VOF (Volume of Fluid) methods can be categoried by the interface reconstruction method. Depending upon the method used in computing the interface normal (slope):
1.One-dimensional (operator split) 2.Multi-dimensional
Question:
What does it mean by one-dim of multi-dim? What is the meaning of the noun "operator split"?
Old   September 20, 2001, 10:26
Default Re: Explain VOF Reconstruction Method
Mr Split personality
split method means that your reconstruct and advect in one direction say the x direction then you repeat for the other direction say the y direction instead of a multidimensional (or unsplit) method where the advection and reconstruction is done in one step.
A simple split method tends to be more accurate than the unsplit method (if one takes into consideration the directional bias) thus it tends to be more dispersive and one may need to build in a flux limiter to the algorithm.
sorry I think I am babbling now.
How to apply VOF method? yeeking86 CFX 7 August 23, 2010 18:24
VOF method yapalparvi Main CFD Forum 0 June 12, 2009 22:27
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
VOF method on inter-tank transfer Louis FLUENT 0 March 14, 2006 09:28
Moving mesh or VOF? Giovanni Main CFD Forum 16 September 24, 2001 08:25
