July 14, 2016, 12:16 |
meshing different regions accordingly
Rep Power: 10 |
I have one big fluid volume in which I know that within a specific region a very fine grid is favourable (if not necessary). I guess using a decent mesh size for the entire volume is not possible since it costs too much, but doing it just in the preselected area might do the job. Is that possible and if so how do u do that? Do you need to have 2 volume bodies already created in the CAD or can you still choose the regions afterwards within the meshing program and if so, how?
July 14, 2016, 13:34 |
Rep Power: 10 |
according to http://www.cfd-online.com/Forums/ans...tml#post416246
I do not need to subdivide my region prior by using body of influence but all tutorials I found so far always have two bodies!?! |
July 23, 2016, 18:04 |
Mikko
Rep Power: 12 |
This depends on which meshing program you are using. Usually, in unstructured meshing you can define a geometric object such as cube and then you can define different cell sizes inside and outside of the cube. |
July 23, 2016, 19:39 |
Rep Power: 10 |
But that implies that these objects are part of a multibody so to say selectable...Not just one big body, right?
July 24, 2016, 04:12 |
Mikko
Rep Power: 12 |
The refinement region (geometric object) is defined at the meshing stage. So your body is still just one big body.
chtMultiRegionFoam different properties in (fluid) region(s) | volker1 | OpenFOAM Pre-Processing | 3 | February 4, 2015 06:46 |
Creating mesh regions in ANYS Meshing | Tarjei | ANSYS Meshing & Geometry | 0 | February 28, 2011 12:32 |
[Other] Importing regions from 3rd party meshing programms | suitup | OpenFOAM Meshing & Mesh Conversion | 1 | November 10, 2009 09:40 |
Multiregion meshing with interface in between regions | bhaskar | STAR-CCM+ | 2 | June 23, 2009 06:06 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
