Home > Forums > Special Topics > Mesh Generation & Pre-Processing
How to create the surface stl file of cylinder
Old   July 3, 2020, 23:04
Default How to create the surface stl file of cylinder
saatt is on a distinguished road
Hi all
How to create the surface file of cylinder, just the riser part, no bottom and top face.
How to create it in Gmsh or FreeCAD or others?
Please give me some suggestions.
saatt is offline   Reply With Quote
Old   July 24, 2020, 07:02
Tommaso M.
TommyM is on a distinguished road
Hi Saatt,
You have to create the cylinder geometry with a CAD software (SolidWorks, FreeCAD, ...), for example simply extruding it from a circle. Then, you save it in .stl format and put it in the constant/triSurface folder of your case. After that, you create the mesh (blockMesh) and extract the geometry from the stl (surfaceFeatureExtract). Finally, you use snappyHexMesh to "adapt" the mesh to such geometry.
Anyway, in this way you will have a single patch, i.e. the cylinder (you cannot have, for example, bottom, top and lateral face patches). I think this is due to the way the cylinder is created by the CAD software.
I am looking for a way to create it as an "assembly of patches" in order to set different boundary conditions on each face. If anyone knows how to do it, I would appreciate your help.
Tommy
TommyM is offline   Reply With Quote
stl file; gmsh; freecad
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
