May 8, 2020, 18:34 |
Salome Shaper: TUI Recover Operation
Carl Reilly
Rep Power: 15 |
I am trying to use the TUI to script some automated geometry creation in Shaper. I have imported two cubes (.step), then drawn some cylinders on one surface of the cube. We'll call this the "internal geometry". This geometry is then placed inside a large cube. I then do a cut operation to subtract the internal geometry from the large cube. The cut process consumes the internal geometry. In order to recover the internal geometry I use the Recover feature (model.addRecover) however I can't get it to work. It executes with no error, but does not recover the part. When i view the result in the GUI i see the action listed in the object tree, but is i select edit, i find that the geometry to recover check boxes are not checked. Am I using the wrong geometry definition? Has anyone else managed to successfully use the recover command with the TUI. I've attached my script and files which should be relatively easy to follow. Note the .TXT needs removing from the .py and .STEP files. I'm struggling to find any help in the documentation. Also I can't seem to gain access to the Salome Forum, as I've not had a response to my email requesting an user name. |
December 7, 2020, 09:20 |
#2 | |
Franco
Rep Power: 6 |
sorry to bother you, I was an GEOMETRY user, and I was trying to learn SHAPER, I work only in TUI but I am having a lot of problems with SHAPER TUI, I feel like I am missing documentation, as even after a read everything i could I still dont figure some things. I though that you might be able to help me as I can imagine that as an OF user you found yourself with the same issues. I was trying to create groups automatically that are in a precise location. 3 in total: the two first groups are faces that are placed in a two different planes and the third is all the other faces. in GEOMETRY I was doing this without problem using: Code:
Plane_1 = geompy.MakePlane(Vertex_0B, OZ, D*10) geomObj_1 = geompy.GetInPlace(fluid, Plane_1, True) Plane_2 = geompy.MakePlane(Vertex_0A, OZ, D*10) geomObj_2 = geompy.GetInPlace(fluid, Plane_2, True) geomObj_3 = geompy.SubShapeAll(fluid, geompy.ShapeType["FACE"]) Group_1 = geompy.CreateGroup(fluid, geompy.ShapeType["FACE"]) geompy.UnionList(Group_1, [geomObj_1]) Group_2 = geompy.CreateGroup(fluid, geompy.ShapeType["FACE"]) geompy.UnionList(Group_2, [geomObj_2]) Group_3 = geompy.CreateGroup(fluid, geompy.ShapeType["FACE"]) geompy.UnionList(Group_3, geomObj_3) geompy.DifferenceList(Group_3, [geomObj_1, geomObj_2]) Code:
filt_2= model.addFilter(name = "OnPlane", args = [Plane_4.result()]); filt_1= model.addFilter(name = "BelongsTo", args = [Cylinder_1.result()]); faces= model.filters(Part_1_doc, [filt_1, filt_2]) model.do() Group_1 = model.addGroup(Part_1_doc, "Faces", [faces]) best regards, |
September 27, 2023, 11:08 |
Juan Camilo
Hello Franco.
Sorry to bother you, I'm struggling with the same problem with shaper. Could you solved it? Best regards |
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so | immortality | OpenFOAM Pre-Processing | 15 | April 7, 2024 12:35 |
[Salome] SALOME and Partition operation problems | kandelabr | OpenFOAM Meshing & Mesh Conversion | 8 | April 28, 2021 20:40 |
Salome Error Importing .step to Shaper > Geom > Mesh | carl_r | Mesh Generation & Pre-Processing | 1 | May 7, 2020 23:03 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
Incompatible dimensions for operation | ruben23 | OpenFOAM Running, Solving & CFD | 2 | June 12, 2015 04:14 |
