Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Error in DsmcCloud::collisions() in dsmcFoam
Like Tree2Likes
  • 2 Post By DSMC123
Old   November 20, 2014, 04:08
Default Error in DsmcCloud::collisions() in dsmcFoam
wenjie
wenjie is on a distinguished road
Hi all,
I think I just found a possible error in the DsmcCloud::collisions() in DsmcCloud.C .
There, in the number of collision pairs, it should be nC * nC instead of nC* (nC-1) according to Bird's book (p219).
Does anybody agree or disagree with me?
-Wenjie
wenjie is offline   Reply With Quote
Old   November 23, 2014, 15:09
Retired Super Moderator
Bruno Santos
Greetings Wenjie,
I had a look at the source code and took me a while to spot the piece of code you were referring to:
            scalar selectedPairs =
                collisionSelectionRemainder_[cellI]
              + 0.5*nC*(nC - 1)*nParticle_*sigmaTcRMax*deltaT
               /mesh_.cellVolumes()[cellI];
            label nCandidates(selectedPairs);
            collisionSelectionRemainder_[cellI] = selectedPairs - nCandidates;
To me, the use of "nC-1" is because the current particle isn't counted in possible collisions. Nonetheless, I have no idea which exact book you're referring to
It's possible that the implementation done in OpenFOAM is either based in a more recent paper or version of said book, or it could be the other way around, where they could have based themselves only on the very first edition of the book.
In addition, according to this git blame: https://github.com/wyldckat/OpenFOAM...ud/DsmcCloud.C - that specific part of the code you're referring to exists since the first commit for OpenFOAM 1.6.x, so there is the possibility that this is still pending some additional revision.
Best regards,
Bruno
Old   November 24, 2014, 07:16
wenjie
Originally Posted by wyldckat View Post
Greetings Wenjie,
Best regards,
Bruno
Hi Bruno,
Yes, that's the code that I was talking about. Indeed by using nC*(nC-1) instead of nC*nC, you are not counting the current particle, but it is explained in the Bird's book "Molecular Gas Dynamics and the DIrect Simulation of Gas FLows" on page 219 that the number of choices should be N^2 /2 instead of N(N-1) /2 for large number of gas molecules and this error becomes significant for small values of N. And the whole rest part is about how to increase the probability and decrease the fraction.
So I still think that nC*nC should be the correct one to use here. What do you think?
Best,
Wenjie
Old   November 25, 2014, 05:57
Craig White
DSMC123 is on a distinguished road
It has to be N*(N-1) for the no time counter model to be correct. See section 7 in this document from Graham Bird: http://www.gab.com.au/dsmc07notes.pdf
In addition, a quick look at Bird's 1D source code confirms that he uses the N*(N-1). This is from line 5989 of DS1.f90:
ASEL=0.5D00*ICCELL(2,N)*(ICCELL(2,N)-1)*WFC*FNUM*CCELL(4,N)*DTC/AAA+CCELL(2,N)
Where ICCELL is the number of particles in the cell.
wyldckat and wenjie like this.
DSMC123 is offline   Reply With Quote
Old   November 25, 2014, 11:32
wenjie
HI Bruno,
Thanks for the document!. Now it's clear : )
dsmcFoam setup hherbol OpenFOAM Pre-Processing 1 November 19, 2021 01:52
[OpenFOAM] - Coupling dsmcFoam and laplacianFoam costrom OpenFOAM 0 October 26, 2014 15:15
ForceCoefficients/MachNumber for dsmcFoam CFDnewbie147 OpenFOAM Running, Solving & CFD 0 April 10, 2014 10:18
dsmcFoam unanswered questions... CFDnewbie147 OpenFOAM 0 February 11, 2014 01:23
how can I Run axisymmetric flow using dsmcFoam ? mechy OpenFOAM 4 September 19, 2011 10:25
