Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Mass conservation error overInterDyMFoam (OF v.1706)
Like Tree3Likes
  • 3 Post By ngj
Old   July 19, 2017, 06:27
Default Mass conservation error overInterDyMFoam (OF v.1706)
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Dear all,
I tried making a bug-report here (https://develop.openfoam.com), though I was not allowed to open a new issue. Therefore, I will report the bug here instead and hope that it is picked up.
OpenFoam version:
v1706
Solver:
overInterDyMFoam
Tutorial:
floatingBody
Modifications:
1. In the file background/constant/dynamicMeshDict, I set the property accelerationRelaxation to a value of 0.0. This effectively allows for the modelling of a fixed, floating box.
2. I extended the simulation time to something like 50 s instead of the 4.0 s in the tutorial.
3. I removed the damBreak component of the setFieldsDict, such that the water level is flat.
Observed behaviour:
After the modifications, the tutorial essentially models a fixed box in a closed container. It was expected to observe a stagnant solution. The only complication being that the fixed box is treated with the overset functionality.
It was rather observed that the water quickly drained from the computational domain. I expect that there is something happening on the interface of the two computational grids, but it was not apparent, what exactly happens in the overset-functionality, so I do not have any suggested solution.
Kind regards and thank you for looking into this,
Niels
P.S. I am very happy to see this new development and I see many possible applications, where we are currently restricted.
roenby, yuhan1991 and dupeng like this.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   July 19, 2017, 07:25
Mattijs Janssens
You'll have to register to post on develop.openfoam.com. Can you please post your issue on the issue tracker?
Thanks,
Mattijs
Old   July 19, 2017, 08:49
ngj
Hi Mattijs,
I did register, but every time I click on "New Issue", I simply get the list of current issues.
I have tested in both Firefox and Explorer with the same outcome.
Kind regards,
Niels
Old   July 19, 2017, 11:05
Mattijs Janssens
Did you log in? Are you accessing https://develop.openfoam.com/Development/OpenFOAM-plus?
Old   July 19, 2017, 11:12
ngj
Hi Mattijs,
Sorry for the late reply.
Yes, I log in and I still experience the same behaviour, namely that I cannot submit issues. I can see that you have opened an (related?) error, so thank you.
Kind regards,
Niels
Old   July 19, 2017, 12:49
Mattijs Janssens
We can masquerade as you and go to project, click on New Issue and all looks normal. Strange.
Old   July 19, 2017, 15:15
ngj
Hi Mattijs,
I am so sorry for the inconvenience. I went directly to "Issues" with the left drop-down menu, instead of choosing the project and then issues. The latter works, not the former.
I have added some feedback to your code change. I see some improvement, but it is not fixed yet. Let us continue in the bug-tracker.
Kind regards,
Niels
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 20:47
mass conservation problem with VOF model pat77 FLUENT 6 February 24, 2017 04:39
Can FVM have mass sinks/ mass conservation problems? whuup FLUENT 0 March 8, 2014 18:48
mass conservation in VOF method meith Main CFD Forum 2 August 12, 2010 11:30
2D mass conservation could be splitted or not? nashiong Main CFD Forum 2 July 4, 2010 17:35
