[swak4Foam] linear inlet velocity profile
Old   January 8, 2014, 11:22
Default linear inlet velocity profile
eRzBeNgEl is on a distinguished road
Hi guys,
i want to create a linear velocity profile at the inlet patch for simulating couette flow in a channel with less computational effort, therefore I tried following code:
inlet
type groovyBC;
variables "maxVel=1;yp=pts().y;minY=min(yp);maxY=max(yp) ;";
valueExpression "((maxY-minY)/maxVel)*normal()*time();";
value uniform (1 0 0);
Is this right? I already set the maximal velocity in the U description of a moving wall (velocity = 1 m/s). Is there an option to link the groovyBC (maxVel part) with this boundary condition, eg: "maxVel=mag(U)@movingWall";
eRzBeNgEl is offline   Reply With Quote
Old   January 9, 2014, 05:32
any idea? my results are not right, so there must be a mistake
Old   January 9, 2014, 16:20
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by eRzBeNgEl View Post
Hi guys,
I'm not completely clear what you exactly want to do. You mean something like "maxVel{movingWall}=max(U)"? ( see http://openfoamwiki.net/index.php/Co...al_expressions or the incomplete reference guide)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   January 10, 2014, 04:56
in general I will produce a linear gradient velocity profile at my inlet in y-direction
This is my test setup
1. I tried by groovyBC but I failed -
2. I changed the hard coded parabolicVelocity.C File of HJasak and got the profile at figure 1. - it seems to be right
BUT
if i calculate further I got wiggles at the corner on bottom. How can I avoid them?(see Figure 2 & Figure 3) and in Couette there should be no velocity gradient in y-direction, but there is!
and in general, how can I set this profile to whole domain and not just to the inlet?
Here is my Member Function of the linear velocity profile:
void linearVelocityFvPatchVectorField::updateCoeffs()
    if (updated())
        return;
    // Get range and orientation
    boundBox bb(patch().patch().localPoints(), true);
    vector ctr = (bb.max() + bb.min());
    const vectorField& c = patch().Cf();
    // Calculate local 1-D coordinate for the linear profile
    scalarField coord = ((c - ctr) & y_)/((bb.max() - bb.min()) & y_);
   //n=flow direction, maxValue=peakVelocity
    vectorField::operator=(n_*maxValue_*(1.0-sqr(coord)));
Old   January 11, 2014, 17:10
Retired Super Moderator
Bruno Santos
Greetings to all!
@eRzBeNgEl: There are several details here that are either missing or that you are not taking into account:
  1. The correct way to be properly that the values are as you want them, is to see the cell data, not the point data. See this post for more information: http://www.cfd-online.com/Forums/ope...tml#post446469 post #12
  2. You are not telling us what boundary conditions you are using for the walls, namely the ones that are perpendicular to the inlet. Or at least, I did not understand it from your description.
  3. I have not understood why you need to use this boundary condition for the inlet. Because a simple modification to the cavity tutorial could give you the couette flow, without any special boundary conditions.
  4. You can set the whole domain to have the desired flow, by using funkySetFields: http://openfoamwiki.net/index.php/Co...funkySetFields
  5. The code you've provided does not seem to have been modified. It's still a parabolic flow, because of this specific detail:
    1.0-sqr(coord)
Best regards,
Bruno
Velocity inlet BC profile antonio.c FLUENT 1 November 1, 2017 14:22
atmBoundaryLayerInletVelocity - Velocity Profile not continuous through domain sdfij6354 OpenFOAM Running, Solving & CFD 3 July 26, 2017 16:16
extracting outlet velocity profile from one case to another case's inlet tonggysun OpenFOAM 2 September 13, 2013 04:19
Export & Import Velocity profile as Inlet eRzBeNgEl STAR-CCM+ 6 March 26, 2012 05:16
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
