[PyFoam] does not want to plot
Like Tree2Likes
  • 1 Post By mich_K
  • 1 Post By gschaider
Old   August 10, 2014, 07:30
Default does not want to plot
Michael Kruger
mich_K is on a distinguished road
When I run a case normally it runs fine.
However when I run it as pyFoamPlotRunner.py simpleFoam, it seems to run fine and creates a bunch of pyFoam files and directories in the case directory, but does not plot any of the required residuals. Gnuplot does not even open.
I am not getting any errors and do have gnuplot installed.
Any suggestions?
Thanks in advance.
vs1 likes this.
Michael
mich_K is offline   Reply With Quote
Old   August 10, 2014, 16:35
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Any suggestions?
Thanks in advance.
Look at the date of your posting: Gnuplot refuses to work on Sundays. PyFoam works on sundays but respects the right of Gnuplot to have a day off.
No seriously. I guess you did your research and it is not the well known "I work with Ubunutu where there is a gnuplot and a gnuplot-x11-package. The first is installed by default the second one is the one I want because it draws windows"-problem. Please check whether Gnuplot draws windows if used by itself. If that works (and only then) the problem is PyFoam. Is there ANY output in the beginning that could give a hint about the problem
vs1 likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   August 10, 2014, 16:58
anonymous
ssss is on a distinguished road
As explained by gschaider, you should be seeing an error at the start, which says something about "X11:missing"
To solve this run:
sudo apt-get install gnuplot-x11
After that you can run:
pyFoamPlotRunner simpleFoam
And it should work, although I would recommend you using
pyFoamRunner.py --progress simpleFoam
And after that run
pyFoamPlotWatcher.py --silent PyFoamRunner.simpleFoam.logfile --hardcopy
Which should give you nicer plots, and will have better performance in your simulation.
ssss is offline   Reply With Quote
Old   August 11, 2014, 02:24
Michael Kruger
I agree it was unfair of me to ask gnuplot to work on a Sunday (-:
Thank you both sssss and gschaider for helping a newbie out. Success!
Another question on pyFoam,
how does the ClearCase command work?
When I run pyFoamClearCase.py in the case directory it gives an error and says I have to specify a parameter, what parameter is this?
Also, on another subject, might one of you be able to help me with these questions:
http://www.cfd-online.com/Forums/ope...r-surface.html
http://www.cfd-online.com/Forums/ope...lon-omega.html
http://www.cfd-online.com/Forums/mai...nce-study.html
Michael
Old   August 11, 2014, 04:40
Assistant Moderator
Bernhard Gschaider
The directory you want to clear. In your case a simple . will be sufficient.
It HAS been asked in the past whether I could make this utility run parameter-less, but I'm a strong believer in the second Zen of Python ("Explicit is better than implicit". See http://legacy.python.org/dev/peps/pep-0020/)
Due to time constraints I limit my answering to some topics (PyFoam is one of them, but these are not)
Old   August 11, 2014, 04:57
Michael Kruger
Understandable.
Thanks Bernhard!
Michael
Old   February 22, 2015, 14:59
Avdeev Evgeniy
j-avdeev will become famous soon enough
Send a message via Skype™ to j-avdeev
Hello.
I have similar problem as mich_K. It is sunday and pyFoam does not want to plot.
I have installed pyFoam and gnuplot as "notroot" user to my home directory.
gnuplot works fine - after command "plot sin(x)" window appears.
But if I run pyFoamPlotRunner
]$ pyFoamPlotRunner.py potentialFoam
|  \\    /   O peration     | Version:  2.2.2                                 |
Build  : 2.2.2-9739c53ec43f
Exec   : potentialFoam
Date   : Feb 22 2015
Time   : 22:41:38
Host   : "mgt1"
PID    : 21491
Case   : /home/avdeev/OpenFOAM/OpenFOAM-2.2.2/tutorials/basic/potentialFoam/pitzDaily
nProcs : 1
Create time
Create mesh for time = 0
Reading field p
Reading field U
No finite volume options present
Calculating potential flow
DICPCG:  Solving for p, Initial residual = 1, Final residual = 9.18464e-07, No Iterations 221
 PyFoam WARNING on line 142 of file /home/avdeev/python27/lib/python2.7/site-packages/PyFoam/LogAnalysis/GeneralLineAnalyzer.py : Problem doing timelines could not convert string to float:
continuity error = 1.60712e-05
Interpolated U error = 0.000110442
ExecutionTime = 0.29 s  ClockTime = 1 s
End
pyFoam makes files, but no plot windows
$ ls
0         Allrun                pitzDaily.foam                      PyFoamServer.info           PyFoamState.StartedAt
0.org     constant              PyFoamHistory                       PyFoamState.CurrentTime     PyFoamState.TheState
Allclean  Gnuplotting.analyzed  PyFoamRunner.potentialFoam.logfile  PyFoamState.LastOutputSeen  system
And also I have no Qt installed - is it matter?
$ pyFoamVersion.py
Machine info: Linux | mgt1 | 2.6.18-398.el5 | #1 SMP Tue Aug 12 06:26:17 EDT 2014 | x86_64 | x86_64
Python version: 2.7.7 (default, Jun 27 2014, 12:11:28)
[GCC 4.5.2]
Python executable: /home/avdeev/python27/bin/python
Python 2.7 is one development platform for PyFoam (along with Python 3)
PYTHONPATH: /home/avdeev/OpenFOAM/ThirdParty-2.2.2/platforms/linux64Gcc45/paraview-3.12.0/Utilities/VTKPythonWrapping:/home/avdeev/OpenFOAM/ThirdParty-2.2.2/platforms/linux64Gcc45/paraview-3.12.0/lib/paraview-3.12:/home/avdeev/OpenFOAM/ThirdParty-2.2.2/platforms/linux64Gcc45/paraview-3.12.0/Utilities/VTKPythonWrapping:/home/avdeev/OpenFOAM/ThirdParty-2.2.2/platforms/linux64Gcc45/paraview-3.12.0/lib/paraview-3.12:/home/avdeev/OpenFOAM/ThirdParty-2.2.2/platforms/linux64Gcc45/paraview-3.12.0/Utilities/VTKPythonWrapping:/home/avdeev/OpenFOAM/ThirdParty-2.2.2/platforms/linux64Gcc45/paraview-3.12.0/lib/paraview-3.12
Location of this utility: /home/avdeev/my_python/bin/pyFoamVersion.py
 PyFoam WARNING on line 192 of file /home/avdeev/python27/lib/python2.7/site-packages/PyFoam/FoamInformation.py : Basedir /home/avdeev/foam for fork extend does not exist or is not a directory
Version 2.2.2 Fork openfoam of the installed 3 versions:
openfoam-2.1.1 : /home/avdeev/OpenFOAM/OpenFOAM-2.1.1
openfoam-2.2.0 : /home/avdeev/OpenFOAM/OpenFOAM-2.2.0
openfoam-2.2.2 : /home/avdeev/OpenFOAM/OpenFOAM-2.2.2
pyFoam-Version: 0.6.4
ALERT: Reported version (0, 6, 4) is different from hardcoded version (0, 6, 4, 'development') -> probably inconsistent library installation
Path where PyFoam was found (PyFoam.__path__) is ['/home/avdeev/python27/lib/python2.7/site-packages/PyFoam']
Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/avdeev/.pyFoam/pyfoamrc'), ('directory', '/home/avdeev/.pyFoam/pyfoamrc.d')]
Configuration files (used): []
Installed libraries:
cython               :  No 	 Not used. Maybe will by used later to spped up parts of PyFoam
cProfile             :  Yes
docutils             :  No 	 Not necessary. Needed for RestructuredText to HTML conversion
Gnuplot              :  No 	 Not a problem. Version from ThirdParty is used
hotshot              :  Yes
ipdb                 :  No 	 Not necessary. Only makes debugging more comfortable
IPython              :  No 	 Not necessary. But the interactive shell may be more comfortable
matplotlib           :  No 	 Only Gnuplot-plotting possible
mercurial            :  No 	 Not a problem. Used for experimental case handling
nose                 :  No 	 Only needed for running the unit-tests (developers only)
numpy                :  Yes 	 version: 1.8.1
openpyxl             :  No 	 Not a problem. Only used for exporting pandas-data to Excel-files (advanced)
pandas               :  No 	 Not a problem. Only used for handling of advanced data-handling
ply                  :  No 	 Not a problem. Version from ThirdParty is used
profile              :  Yes
psyco                :  No 	 Not a problem. Acceleration not possible
PyQt4                :  No 	 Only some experimental GUI-stuff relies on this
PyQt4.Qwt5           :  No 	 Only an alternate plotting back-end
scipy                :  No 	 Not yet used. Possibly use signal-fitting etc
Tkinter              :  No 	 Not a problem. Used for the old version of DisplayBlockmesh and some matplotlib-implementations
twisted              :  No 	 Not yet used. Possibly reimplement MetaServer with it
vtk                  :  No 	 Not a problem. Only used for some utilities
xlwt                 :  No 	 Not a problem. Only used for exporting pandas-data to Excel-files
xlrd                 :  No 	 Not a problem. Only used for importing Excel-files to pandas-data
Library locations
cProfile             : /home/avdeev/python27/lib/python2.7/cProfile.pyc
hotshot              : /home/avdeev/python27/lib/python2.7/hotshot/__init__.pyc
numpy                : /home/avdeev/python27/lib/python2.7/site-packages/numpy/__init__.pyc
profile              : /home/avdeev/python27/lib/python2.7/profile.pyc
Checking additional envirnoment variables
Checking for PYFOAM_DIR : Location of the PyFoam-installation. Not strictly necessary
PYFOAM_DIR missing from environment
Checking for PYFOAM_SITE_DIR : Location of non-PyFoam-disctributions script. Set and used by some Foam-distributions
PYFOAM_SITE_DIR missing from environment
Thanks in advance.
j-avdeev is offline   Reply With Quote
pyfoam, simplefoam
Contribute a forceCoeff plot and merge utility lakeat OpenFOAM Running, Solving & CFD 5 October 5, 2018 22:48
XY plot is not showing the surfaces I need to plot for. rnb13143 FLUENT 0 April 4, 2017 10:09
[OpenFOAM] Convergence validation with Plot Over Time jam68 ParaView 1 February 11, 2017 17:05
[swak4Foam] Foam warnings - related to swak4Foam Salam-H OpenFOAM Community Contributions 20 August 2, 2015 15:40
graph plot anindya Main CFD Forum 2 September 17, 2003 12:00
