[cfMesh] generate terrain mesh with many components |
October 9, 2019, 01:09 |
Junting Chen
Rep Power: 10 |
Hello all,
I am wondering if there is a way to generate a terrain mesh that has a terrain stl as the bottom of the bounding box (the bottom follows the terrain contour). Also the stl geometry to be subtracted has many components because different cell size will be applied to each component. Is there a way to write it into the meshDict? JT |
October 9, 2019, 08:36 |
Carlo_P
Rep Power: 7 |
Hey,
for sure you can do with snappy, so, in this case maybe snappy is better. Otherwise, you have to create your solid domain in some CAD software and then use in CfMesh the solid domain as stl. Another workaround is an original mesh with snappy, then use foamToSurface to create a stl file and then use CfMesh. This should works |
October 9, 2019, 17:19 |
Junting Chen
Rep Power: 10 |
Thanks Carlo, I have solved this issue. In face, cfMesh can handle terrain stl, although I don't know how it work since I didn't define a point in mesh as in snappy. There was a leak on my stl terrain which caused the issue.
I have few more issues I hope you can help me. I am generating mesh for pretty complex geometry. The output message reports a lot of warnings regarding non-ortho, high skewness and zero volume cells. They do in the end impact the CFD simulation, RANS or LES. Non-ortho and high skewness are in the range of 300-2000, and zero volume cells are around 50 - 100 in the end. How do you deal with those? Another question is how to you capture the feature edges around the body? Lots of straight faces have edges like zigzag lines. I used surfaceFeatureEdges <in> <out> angle 20 to get a output vtk featureEdges. It seems not good enough. Thanks a lot! JT |
October 10, 2019, 04:50 |
Kmeti Rao
Rep Power: 7 |
Hi Junting Chen, It is always difficult to capture the exact geometry during meshing, when your object is so complex and has a lot off sharp edges. Although you can preserve every edge and patch using Salome or any other tool, at the end you need to create very small cells in those regions, which sometimes result in bad cells. Please think of simplifying your model as far as possible, de-featuring your model will dramatically increase the mesh quality. You can refer this link if you want to know more about capturing features using Salome https://curiosityfluids.com/2019/02/...-your-meshing/
Krao |
October 10, 2019, 08:17 |
Carlo_P
Rep Power: 7 |
Hey chen112p , the skweness would affect a lot your results, non-ortho a little less. You can use non ortho correctos in the fvSolution.
In the end, it is not the best. Zero volume is quite always related to shitty stl file. In which cad are you deisgning? It would be better to import maybe in salome of freecad and then reexport. During the mesh with cfMesh don't look to much at the warning. Consider only the erro in checkMesh. |
October 10, 2019, 14:52 |
Junting Chen
Rep Power: 10 |
All stls were created in Rhino. I figured most of the bad cells were created when boundary layers colliding at corners. So i took the advice from Kmeti's link, commented boundaryLayers section in the system/meshDict first and run cartesianMesh; then create boundary layers with generateBoundaryLayers command.
I tried it and did receive much less bad cell (almost nothing in fact!), but I am not sure how to use generateBoundaryLayers command. Seems like it reads in the meshDict again because there is a something going on when I uncomment the boundary layer section. But the mesh generated still has no boundary layer as I checked from paraview. I haven't looked into the source code yet, thats probly what I am going to do. Can you drop me some hints on running generateBoundaryLayers? Also it seems improveMeshQuality can help, but I haven't tested it. My geometries are indeed quite complex.. such as thin shell, concave corners... Thanks for the help! |
October 10, 2019, 14:57 |
Junting Chen
Rep Power: 10 |
Thanks Kmeti, that's a very helpful link. I did see it before but not carefully. I found that tip where not creating boundary layer at first but run generateBoundaryLayer command after a mesh is created is quite interesting. Once I commented out the boundaryLayers section from the meshDict, bad cells did reduce to almost nothing. But can you give me some hint on running generateBoundaryLayers command? -help didn't really give me much information. Does it go into the meshDict again and look for boundaryLayers section? and how do you tell cfmesh at which boundary to create how many layers of boundary layer?
Thanks a lot! JT |
October 11, 2019, 03:39 |
#8 | |||||
Kmeti Rao
Rep Power: 7 |
Hi Junting,
Good to hear that you made some progress, as you have mentioned you should comment out the boundary layer section part of the mesh dict and run cfMesh. After generating the mesh, you shoud go to the mesh dict and comment out the boundaryLayers section and then in terminal you should just type 'generateBoundaryLayers'. The mesh will read only that part and add layers into your mesh. Quote:
K. Rao |
October 11, 2019, 07:41 |
#9 |
Carlo_P
Rep Power: 7 |
I didn't understand if you are using CfMesh or Snappy.
Sorry. With Snappy, the best is to run buonadarylayer with 1 nofLayer and use refineWallLayer in order to increase the number of layers. http://openfoamwiki.net/index.php/RefineWallLayer with snappy, you can also use this tool: https://cfdfeaservice.it/index.php/2...snappyhexmesh/ but, I repeat, the best is to work with snappy, without boundary layer, use foamToSurface and then use cfMesh. If you can provide a picture a the geoemtry can be better. Thanks! |
October 11, 2019, 17:33 |
#10 |
Junting Chen
Rep Power: 10 |
Thanks Kmeti and Carlo, these are helpful information.
Carlo: I have solved the terrain problem. Now the issue is the building geometries on the terrain. In fact, i noticed that buildings are the issue so I am using flat base. I have tried what you said: use blockMesh -> snappy -> cartesianMesh (no boundary layer). Up to this point, i agree the mesh is visually better than straight up doing cartesianMesh. Once I call generateBoundaryLayer function, the sharp edges at corners will be somehow chamfered. Also, I noticed that edges which are not aligned with xyz coordinates become messed up (zig-zaged), perhapes due to the boundary layer generation? Is that something you see? A bit of chamfer I guess is fine, but sharp edges are somewhat a key feature I am trying to maintain... However, with all methods I have tried (some cases sharp edges are maintained, some got chamfered, with boundary layer mesh or without), pimpleFoam always break / diverge. With the same setup, snappyHexMesh converges pretty easily. One thing I might did wrong. In the section of renameBoundary section in meshDict, although newType patch was given to inlet / outlet, they are always set as defaultType (wall), which will be reflected in constant/polyMesh/boundary after the mesh generation. So I have to manually change the boundary condition of inlet and outlet to patch in constant/polyMesh/boundary. Is something I should do? Thanks again, Kmeti and Carlo! |
October 14, 2019, 02:23 |
#11 | ||
Kmeti Rao
Rep Power: 7 |
You can use renaming as mentioned below, instead of newType use type. Quote:
October 14, 2019, 04:04 |
#12 |
Carlo_P
Rep Power: 7 |
Hey Chen, this is an example of changeDict:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | |*---------------------------------------------------------------------------*| | File created by Carlo Pasquinucci for Tecnohit S.r.l | | www.tecnohit.it info@tecnohit.it | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object changeDictionaryDict; } //dictionaryReplacement //{ boundary { "In.*" { type patch; // inGroups 2 (inlet); } "Out.*" { type patch; // inGroups 3 (outlet); } "Symm.*" { type symmetry; // inGroups 4 (symmetry); } } you can find the file here : https://github.com/Carlopasquinucci/ShareOpenFOAMFile Second, with cartesianMesh you can create a very nice boundayLayer. You don't need to use generateBoundaryLayer function. If you want, can you share the geoemtry (stl) file? If it not to heavy (1 milion - 10 milion of cells), I would like to mesh it. |
October 15, 2019, 11:21 |
#13 |
Junting Chen
Rep Power: 10 |
Thanks Carlo, please find the stl files in the attachment.
I am basically testing the performance of cfMesh, so currently I am only running relatively simple geometries. One is the most basic geometry which is a single rectangular block (singleBlock.stl) in the fluid domain. The other one has few ramps, edges unaligned with x/y/z coordinate, concave corner joining 3 patches. Although the mesh files I created looks very neat and checkMesh doesn't complain, pimpleFoam never found a easy converge (mostly diverge) for some reasons. In the STLs.zip, files with file names end with *Box_fe.stl were created by: surfaceGenerateBoundingBox xyz.stl xyzBox.stl xMin xMax yMin yMax 0 zMax surfaceFeatureEdges xyzBox.stl xyzBox_fe.stl -angle 30 This is what I usually do to capture the feature edges along with the surface patches in one STL. xyzBox_fe.stl is used in meshDict as my surfaceFile. Also, I would call: surfaceFeatureEdges xyz.stl xyz_fe.fms -angle FMSToSurface xyz_fe.fms xyz.vtu -exportFeatureEdges to generate a file xyz_featureEdges.vtu which contains only feature edges and used in meshDict to refine those feature edges (edgeMeshRefineMent). This seems to be the best way to deal with feature edges I found so far. Also, I attached a zip file called completeSettings4Pimple which contains all the Foam folders for my pimple run, just in case you want to do a quick pimple run. Thanks a lot for your help! Junting Chen |
October 16, 2019, 18:19 |
#14 |
Carlo_P
Rep Power: 7 |
I checked the geometry and I have only three tricks to suggest you.
1) convert your stl in fms. I think that the command is surfaceToFMS . CfMesh works better with FMS. 2) I saw that the box is exactly with the same dimension of the internal geoemtry. The main problem is that you have some part of the zMin in common with the zMin surface of the block. I attach two images..you shold have the second one triangolation. 3) It would be better to have a more dense triangolation, also if the surface are flat. Maybe you can use surfaceRefineRedGreen, but I'm not an expert of this command. Did you run checkSurface and checkMesh? The quality is good? Cheers. I will try to run tomorrow or on the weekend |
October 18, 2019, 12:05 |
#15 |
Junting Chen
Rep Power: 10 |
Thanks Carlo. I have made some progress on this single block geometry by restricting cell size on the boundary.
The bigger problem is the other geometry where it contains concave corner, surface unaligned with cartesian coordinates, and ramps (challenging feature edges). I have successfully run 1st order LES on it but 2nd order diverged very quickly. Seems bad cells are near the ramps. Response to your suggestions: (1) Sure, probably there is some improvement? I have tried ftr and fms. I can't really tell. (2) The outer box was created by surfaceGenerateBoundingBox. The target geometry has to sit on the ground.. So you are suggesting me to subtract the geometry from the box first? (3) I haven't tried that yet. Most error I have seen occurs at edges and corners. I can try it later.. Thanks again Carlo! Junting |
October 15, 2019, 10:53 |
#16 |
Junting Chen
Rep Power: 10 |
Thanks Kmeti, that works now! but still simulation is difficult to converge (easily diverged).
My meshDict for flow past a single rectangular box looks like this: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | cfMesh: A library for mesh generation | | \\ / O peration | | | \\ / A nd | Author: Franjo Juretic | | \\/ M anipulation | E-mail: franjo.juretic@c-fields.com | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object meshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // surfaceFile "/constant/triSurface/singleBlockBox_fe.stl"; maxCellSize 8.0; //boundaryCellSize 3.0; minCellSize 0.2; surfaceMeshRefinement { singleBlock.stl { additionalRefinementLevels 3; surfaceFile "constant/triSurface/singleBlock.stl"; refinementThickness 1; } } edgeMeshRefinement { singleBoxEdges { edgeFile "constant/triSurface/singleBlock_featureEdges.vtk"; additionalRefinementLevels 4; refinementThickness 0.1; } } objectRefinements { //outer box refineOuter { type box; centre (0 0 20); lengthX 100; lengthY 60; lengthZ 40; additionalRefinementLevels 2; } } boundaryLayers { optimiseLayer 1; // Untangling of boundary layers // Works on negative volume cells created // during layer addition // Activate 1 or deactivate 0 // Default value is 1 untangleLayers 1; // No idea what this does, but it's a thing symmetryPlaneLayerTopology 1; patchBoundaryLayers { singleBlock { nLayers 3; thicknessRatio 1.5; maxFirstLayerThickness 0.3; } bottom { nLayers 3; thicknessRatio 1.5; maxFirstLayerThickness 0.3; } } } optimisationParameters { // number of iterations in the procedure for // redciting normal vectors // in the boundary layer (optional) // Default value is 5 nSmoothNormals 5; // number of iterations of the smoothing procedure // optional // Default value is 5 maxNumIterations 20; // Ratio between the maximum allowed layer thickness // and the estimated feature size // Used to limit layer thickness in regions // dominated by curvature (optional) // Value ranges between 0 and 1 // Default value is 0.3 featureSizeFactor 0.3; // activate 1 or deactivate 0 calculation of normals // (optional) reCalculateNormals 1; // Controls the maximum difference of the // layer thickness between two neighbouring points // divided by the distance of the points // lower values enforce uniform thickness distribution relThicknessTol 0.1; // active 1 or inactive 0 // No idea why you would ever set this to 1 allowDiscontinuity 0; } renameBoundary { defaultName fixedWalls; defaultType wall; newPatchNames { xMin.* { newName inlet; type patch; } xMax.* { newName outlet; type patch; } yMin.* { newName south; type wall; } yMax.* { newName north; type wall; } zMin.* { newName bottom; type wall; } zMax.* { newName top; type wall; } OBJECT.* { newName singleBlock; type wall; } } } // ************************************************** *********************** // The geometry is extremely simple.. but still, pimpleFoam breaks all the time. Only once it didn't, but takes a long time to converge. Do you see anything fishy in the setup? With this meshDict, I ran generateBoundaryLayers after cartesianMesh. I tried both methods: generateBoundaryLayers separately or generate boundary boundary layer during cartesianMesh. Simulation still breaks very easily. |
cfmesh |
[ICEM] How to generate this kind of mesh? | mingersai | ANSYS Meshing & Geometry | 51 | February 16, 2017 07:32 |
How to generate a Cartesian 2D Mesh using MATLAB? | sujithsubramanian | Main CFD Forum | 0 | March 9, 2014 15:46 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
