unsure os installation success - is there a test case |
September 9, 2013, 13:42 |
sreibisch
Rep Power: 12 |
Hi all
I am new in using openfoam and just installed the last version under Ubuntu (my first touch with linux...) I tried some of the test cases and now like to make a calculation of a hull in the water. To be sure to have all files in the right place and to have setup the software completly I would like to run a case which I can be sure of to be correct. Can someone give me a link to a samplecase for a hull incl mesh data for me to test my installation. Doesn't need to be complex just reliable (e.g. Wighley). Many Thanks! |
September 9, 2013, 15:31 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Ingenieur5 and welcome to the forum!
Have you studied the 3 tutorial cases from the User Guide? http://www.openfoam.org/docs/user/tutorials.php If not, start by studying them, starting from the page shown on the link above. As for a "wigley hull", have a look at the tutorial "multiphase/LTSInterFoam/wigleyHull". To run it: Code:
cd $FOAM_RUN cd tutorials/multiphase/LTSInterFoam/wigleyHull ./Allrun Bruno
Last edited by wyldckat; September 10, 2013 at 16:23. Reason: Separated the lines that the forum had glued by itself :( |
September 9, 2013, 18:49 |
Joachim Herb
Rep Power: 21 |
Bruno, the link was corrupted: http://www.openfoam.org/docs/user/tutorials.php
Ingenieur5, for the commands of Bruno to work, you have to first copy (all) tutorials into your $FOAM_RUN directory (as described in the above link) |
September 10, 2013, 08:10 |
sreibisch
Rep Power: 12 |
Thanks for the info!
I found the tutorial and just started as described. How long does it take for the calculation usually? regards Sönke |
September 10, 2013, 08:51 |
sreibisch
Rep Power: 12 |
It works!
Installation seems to be OK. Will now try my own model. Thanks again! |
Help Required With Simple Test Case | steph79 | OpenFOAM Pre-Processing | 4 | August 3, 2010 07:45 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Interfoam Droplet under shear test case | adona058 | OpenFOAM Running, Solving & CFD | 3 | May 3, 2010 18:46 |
Porous Media test case | Alex | FLUENT | 0 | April 9, 2006 08:23 |
c1 body test case | Eric Lenormand | Main CFD Forum | 0 | March 2, 2000 06:54 |
