Error Compiling Paraview4.1.0
Old   April 10, 2014, 09:07
Question Error Compiling Paraview4.1.0
WangShuai
npel is on a distinguished road
hello
i'm new in OpenFOAM, my os is OpenSUSE13.1, OpenFOAM Version is 2.3.0, i downloaded the source pack, i followed the steps in http://www.openfoam.org/download/source.php, when if finished building the sources, i try to Compiling Paraview, but it always terminate installing when it reach a 78% process,the error reported that some file can't be found ,i don't know how to Compiling Paraview and the Paraview Reader Module now, i have also tried to reistalling my os, but it doesn't work. is there any way to solve it? or can i use OpenFOAM without Paraview, if i can ,how can i post processing the data?
thanks for reading
npel is offline   Reply With Quote
Old   April 10, 2014, 09:32
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Originally Posted by npel View Post
...but it always terminate installing when it reach a 78% process,the error reported that some file can't be found...
Surely you can do SOMETHING to solve the problem. Find some file and put it in place so it can be found during compilation process.
Be more specific. Post a fragment of the log file with error.
OpenSUSE 13.1 here and OpenFOAM and paraview compilation process was successful.
alexeym is offline   Reply With Quote
Old   April 10, 2014, 10:46
WangShuai
since it's my first time using linux and OpenFOAM, I don't know how to find the file, later I'll show some detailed information, thank you for replying. Can I post process the result calculated by OpenFOAM without Paraview?
WangShuai
Originally Posted by alexeym View Post
Old   April 10, 2014, 10:53
Alexey Matveichev
It depends on what do you mean by post-processing. Copying files from one folder to another can also be "post-processing". If you'd like to visualize results quickly, paraview is the easiest way.
Also on OpenSUSE 13.1 you can install paraview 4.0.1 from standard repository with zypper, it has built-in OpenFOAM reader.
Old   April 10, 2014, 11:04
WangShuai
I'd like to visualize the results, such as can I use Techplot to process it? Thank you for your advice, I'll try it.
Old   April 10, 2014, 11:12
Alexey Matveichev
You can't use Tecplot directly - http://openfoamwiki.net/index.php/Tecplot.
But, I guess, it'll be easier to find that "some file" and build paraview.
Old   April 10, 2014, 15:07
Retired Super Moderator
Bruno Santos
Greetings to all!
Instructions for building OpenFOAM 2.3.0 and ParaView 4.1.0 on openSUSE 13.1 have been available on the wiki for some time now: http://openfoamwiki.net/index.php/In...2.3.0/openSUSE
As for the wiki page about Teplot: it's outdated. The latest Tecplot versions are able to mostly handle OpenFOAM cases, although from what I've read on the forum, it's not yet full-proof.
Best regards,
Bruno
