[Other] Installation problems with OpenFOAM 2.3.x for Windows from cfdsupport.com |
November 3, 2014, 07:49 |
Nikola
Rep Power: 12 |
Hi everyone!
I am experiencing problems while trying to install OpenFOAM on my laptop. I have Windows 7 64bit. When I arrive to step 3 (Install Cygwin64) I cannot go beyond point 7. I have installed cygwin64 correctly and I have created the folder opt/OpenFOAM in which I've copied the two dir.tar.gz files mentioned in the instructions (http://www.cfdsupport.com/install-op...r-windows.html). When I run Cygwin.bat and try to extract the files by typing cd/opt/OpenFOAM I receive the following message: "No such file or directory". I've tried to type /opt/OpenFOAM and in this way the directory is located, but when I try to type the two following commands for extracting the packages I receive the following message "Function "open" failed to function: No such file or directory". What should I do? Thanks in advance! Nikola |
November 3, 2014, 08:57 |
Nikola
Rep Power: 12 |
I apologize, CFD support has replied quickly and I've solved the problem. You can delete this thread!
November 8, 2014, 16:55 |
#3 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
March 31, 2015, 09:32 |
Devon Lybbert
Rep Power: 11 |
March 31, 2015, 10:21 |
Nikola
Rep Power: 12 |
Hi! As long as I recall, I was making some really stupid mistake while typing the code. I think it was this one, but I am not sure. Be carefull and type cd /opt/OpenFOAM instead of cd/opt/OpenFOAM.
March 31, 2015, 10:31 |
Devon Lybbert
Rep Power: 11 |
That doesn't seem to be it, but thanks for your quick reply.
March 31, 2015, 10:34 |
Nikola
Rep Power: 12 |
I've installed it many times, if you can be more specific I may help you!
March 31, 2015, 10:59 |
Devon Lybbert
Rep Power: 11 |
Actually that was the problem. I didn't realize that you NEED the space after "cd". Thanks for your help!
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[Other] openFoam 2.3.x for windows from cfdsupport.com | vasava | OpenFOAM Installation | 44 | May 18, 2016 05:09 |
[Other] openFoam 2.3.x for windows from cfdsupport.com (much easier now!) | vasava | OpenFOAM Installation | 2 | August 24, 2015 06:33 |
[OpenFOAM.org] Installation of OpenFOAM 2.3.0 / 2.3.x on RHEL 5.8 without root permissions | niX1337 | OpenFOAM Installation | 7 | January 12, 2015 03:43 |
OpenFOAM 1.7 Installation problems | shangzung | OpenFOAM Installation | 5 | July 7, 2010 10:34 |
